Hi Guys, anyone using this type of spark plugs from the UK called Brisk High Performance Spark Plugs. I have ordered some as my GU is on LPG . have a look and tell what you think regards Alex
97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
Are you running dedicated LPG or duel fuel? How do you find the vehicle performs on LPG?
Lee
Hi Lee, at the moment I fine the LPG performs better than petrol and I'm up for changing my spark plugs , So I.m trying something different regards Alex
Hi NP99 , your link not working, item has been moved regards Alex
According to wiki
Iridium is the most stable of All metals.
Stable even at 2000 deg C.
where silver melts at approx 900 deg C,
silver plug claims don't make much sense.
I've been using iridium for 10 years ,never a problem.
set gap and forget, never had to adjust it yet in 2 cars running iridium plugs.
GQ tb4.2 after 40000 k on lpg and tip wear non existent.
And a full set of plugs for very similar money.
be interested to see how ya go, some feed back will you, thanks.
According to wiki
Well Robo. car does running alittle better than be4 , but this is after I did the tappers which has been 2 years last done . still getting around 400ks on 90 litres lpg , but I did notice when I switched it over to petrol could tell that I did it and back to lpg . Winner :-) regards Alex
Good stuff, get back in 5000k and let us know how gap is going will ya.
cheers
cheers
Gap in spark plug did you mean as there is none. regards Alex
