24th July 2014, 09:46 PM
Can you use a stethoscope to try and isolate it further?
24th July 2014 09:46 PM
24th July 2014, 09:59 PM
nissannewby
Hose and small funnel.
25th July 2014, 07:42 AM
Sounds are funny things, in my previous car it sounded like a werring noise coming from the front passenger footwell, turned out to be a failed rear wheel bearing.
Cheers Rod
_______________________________________________
Bitumen ...... Another watse of public funds
My Build 2005 TD42TI
29th July 2014, 06:30 PM
Thanks all for your suggestions. I may have found it. Under the bonnet, the rubber strip that runs along the underneath the trailing edge of the bonnet. The end on the drivers side was loose and for what ever reason would make a clicking noise if i moved it. A little bit of silicon underneath it and a drive around the block and the noise is gone! But tomorrow will tell when i drive to work whether i've fixed it or not.
The Following User Says Thank You to Parksy For This Useful Post:
29th July 2014, 07:12 PM
Yep, common issue on the Hilux also, only it's the black plastic between the bottom of the screen and the bonnet, and more so in winter than summer, but I was some what hesitant in bringing that up. LOL!
Cheers Rod
The Following User Says Thank You to Rocket55 For This Useful Post:
1st August 2014, 08:47 PM
A quick update. This did get rid of 90% of the noise, but occasionally it still came back. So I removed the rubber strip completely to clean it all up and stick it down properly and I think this revealed why it's making the noise.
When I re painted the car, the paint pooled onto the rubber section, creating a hard section that would tap onto the body which made the annoying sound. So really, it's my own fault for doing a shody job on the paint job, but at least I'm fixing it properly now.
The Following 2 Users Say Thank You to Parksy For This Useful Post:
mudnut (1st August 2014), ripper (8th August 2014)
8th August 2014, 01:56 AM
#17
Thanks Parksy, ours intermittently has a noise that sounds like the same thing as yours. I'll have to look there next time it does it.
1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
