Page 16 of 19 FirstFirst ... 1415161718 ... LastLast
Results 151 to 160 of 187
Thread: DIY CV and Swivel Hub Rebuild Thread
  1. #151
    Oct 2019
    Hi there, awesome detailed write up, been studying this thread & doing my GQ at the same time getting all the necessary info from the write up, 2 thumbs up for taking the time to share MudRunner....
    Now there’s a question coming...
    The Nissan GQ Patrol manual shows the seal guard(s) being inserted vertically, not horizontally (your pics shows it inserted horizontally), can you plz clarify & confirm?
  2. #152
    Quote Originally Posted by Kon View Post
    That is interesting. Where did you get that pic?? If you refer to the first page you will see.the diagram I use is horizontal. Note also there is a pic clearly showing the back of the swivel hub with them bolted up. The bolt pattern will dictate them anyway. They will only go 1 way.
  3. #153
    Oct 2019
    I believe it’s from the Nissan Patrol GQ/GU manual that Nissan released...
    Interesting because mine are also like yours in the picture...., horizontal...
    Here is the full page of the screenshot
  4. #154
    bed in the rear scraper seal and install the cover plate. This can be a little confusing, take your time and it will bed in perfectly.
    As you can see in these pics the bolt pattern suggested in the image is clearly not correct either.
    As you can see there though, it will only go 1 way.
  5. #155
    Oct 2019
    Yup my actual GQ is exactly like yours as shown in the above post...
    With respects to the scraper seal & supporting ring, do you have the incision facing up or down?
    The manual shows it facing down, others have mentioned it should face up, one member has mentioned to me that it should face down to allow any water to be dispersed in case it enters the swivel knuckle area.
    What are your thoughts?
    P.S.
    Which bolt hole do you use for the 1 special/different looking bolt (stopper bolt) at the back for the scraper seal guards?
  6. #156
    P.S.
    I fit them to the bottom as per the photo above but the swivel hub is sealed and there should be No Water ingress. If water gets in there then your stripping it out anyway for the contaminant.
  7. #157
    Oct 2019
  8. #158
    Just went out and grabbed some photos for you mate.
    View from behind diff on GU
    The steering stop bolt in on the front side on both sides. Clearly visible in these pics.
    And my GQ also runs a GU diff with that same setup.
    Sorry I can't confirm the GQ is the same but I'm nearly 100%
  9. #159
    Note from this photo of my GU that Nissan changed from Horizontal to Vertical from GQ to GU. Learn something every day.
  10. #160
    Oct 2019
    Ok, so I thank you for assisting with the above pictures...
    Seems like mine are exactly like yours...
    I am about to do the rebuild (I’ve got everything just want to get my head around things before I attempt)...
