Page 14 of 19 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 187
Thread: DIY CV and Swivel Hub Rebuild Thread
  1. #131
    Jan 2019
    Thanks so much for this post mud runner! Good to see the comments are still going strong after all these years!
    I just finished rebuilding my swivel hubs only on a GUII with manual locking hubs.
    Love ya work
  2. The Following User Says Thank You to Matty C For This Useful Post:
    MudRunnerTD (13th January 2019)
    Dec 2017
    Finding this thread very helpful so thank you Mudrunner.
    But would you happen to know the part number for the CV brass washer? I cant find it anywhere
  5. #133
    Quote Originally Posted by Hash1112 View Post
    Hi mate, If your struggling i would re-use the one you have mate. they are not really a wear item.
  6. #134
    Dec 2017
    It's damaged pretty bad due to breaking the cv, I'll try to hammer and straighten it may be.
    Thanks for the reply bud I really appreciate what you have done in this thread.
  7. The Following User Says Thank You to Hash1112 For This Useful Post:
    MudRunnerTD (15th January 2019)
  8. #135
    Dunno where you are mate but I have a pair of them at home in Gippsland Victoria
  9. #136
    Dec 2017
    Hey Winnie, thanks mate, I just bought a second hand CV and the bloke gave the washer with it
  10. The Following User Says Thank You to Hash1112 For This Useful Post:
    Winnie (15th January 2019)
  11. #137
    Jul 2017
    Thanks so very much for this. So easy to follow
    After doing all this I'm not sure what oil for the front diff. The hub is an auto locking thingo ma Bob... how can ya tell if the diff is lsd or not? Just worried about using the wrong oil
    Sep 2018
    queensland
    as far as i know there is not front lsd patrol diffs, only rears. mechanics have told me you can put the same rear lsd oil into the front so thats what i do. i think its more expensive because its lsd but i dont pay for it
  13. #139
    Feb 2019
    Thanks a billion MD. Your posts helped me rebuild my swivels. I bought my 96 gq with serious diff oil leak comin out swivel. I think i did it right cause its not leakin any more😅
  14. The Following User Says Thank You to blayne For This Useful Post:
    MudRunnerTD (25th March 2019)
  15. #140
    Ok so i took these pics last year and thought i had uploaded them but did not.
    Here are dome pics for removing the king pin bearings 2 different ways.
    Option 1 needs a bearing removal clamp and a vice.
    Install in vice loosely so it is just sitting in there hanging from the clamp
    Punch and hammer.
    Easy job.
    Lmm grease is great for the wheel bearings and CV
    Option 2 is to use a pair of pointy nose pliers and a flat screw driver. 3 points of contact make light work of it
    Remove the lip seal under the bearing. Just wreck it and rip it out. This makes space for the pliers
    The taper on the pliers will do the work here. Wedge in and work it.
    Screw driver from the other side.
    Wahlah.
  16. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    Clunk (27th March 2019), Plasnart (27th March 2019), Touses (28th March 2019)
