Page 19 of 19 FirstFirst ... 9171819
Results 181 to 187 of 187
Thread: DIY CV and Swivel Hub Rebuild Thread
  1. #181
    Jul 2019
    Hey MudRunnerTD anymore updates on this rebuild Im looking to go ahead have all the gear ready to go
    Quote Originally Posted by trimixdiver View Post
    Nah mate. Good to go. I have added updates and embedded them where they should be in the thread. Everything you need to know is here mate. Any dramas I'm here most days.
  4. #183
    Jul 2019
    Was told to use Molly grease for axle and king pin bearings since its all together inside the hub and use High Temp for wheels bearings if this is correct that means to use 2 different grease so did you use your grease Gadget on both switched out grease in between?
  5. #184
    Hi mate, I would use the Hi Temp grease for the wheel bearings and King Pin bearings. Pack all those using thrbgrease packer. Use the moly grease for the CV and pack this by hand.
  6. #185
    Jul 2019
    Ok cool exactly what I did, also would you chance both side if only one side was leaking, I bought a full kit thinking I should keep as a spare .
  7. #186
    I would do both sides. You are effectively rebuilding the swivel hubs and there will be a noticeable difference when driving.
  8. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    growler2058 (9th October 2021), Rossco (9th October 2021)
  9. #187
    Jan 2023
    That thing is a beaut
