19th July 2014, 01:02 PM
#11
Moderator
deanfurley
Mudrunner, any chance of those pics mate? I'm get the idea just ant to have a look before I start drilling.
Here you go mate. gave me some motivation to actually post this thread!
DIY-Fitting-Side-and-Rear-Awnings-to-Roofrack
Check out my Toy -->
Rogue Dung Beetle
deanfurley (19th July 2014)
19th July 2014 01:02 PM
19th July 2014, 01:04 PM
#12
The 747
MEGOMONSTER
I just drilled through the uprights of the rack and through the awning, with 2 bolts on each of the 3 uprights.
I did the same but on 4 uprights... When I told the bloke at the shop how I did it he said I was mad and he only ever does the 2 end uprights
19th July 2014, 01:15 PM
#13
deanfurley
Thanks Hodge, don't suppose you know what those brackets are called? I just visited ARB at Artarmon, and he just told me they don't do a bracket. And to drill.
Honestly no idea mate. That's what guy at Arb gave me and the bag was Arb labelled. He said use these if you do not want to drill.
Sent from my SM-G900I using Forum Runner
The Following User Says Thank You to Hodge For This Useful Post:
19th July 2014, 04:05 PM
#14
CERTIFIABLY INSANE
Hodge
Honestly no idea mate. That's what guy at Arb gave me and the bag was Arb labelled. He said use these if you do not want to drill. Sent from my SM-G900I using Forum Runner
They look like the Rhino brackets I used on my old school TJM rack. Mine had no real uprights to fix my Rhino awning onto so bracket option it was. They were exxxy (about $90 as I remember). I had some L brackets kicking around here that I modified to mount the rear awning.......
A "bought" bracket
And a modified
Sent from my iPhone using Forum Runner
19th July 2014, 05:29 PM
#15
Moderator
Drewboyaus
A "bought" bracket
And a modified
I reckon you'd get all of that from your local Bunnings Cheap enough! Those L Brackets look allot like Gal Shelf supports.
Rogue Dung Beetle
19th July 2014, 05:58 PM
#16
CERTIFIABLY INSANE
MudRunnerTD
Probably, but I don't really have too many tools for metal fabrication. I used to when I worked for a previous employer......They had a whole fabrication workshop full of stuff to play with.
19th July 2014, 10:46 PM
#17
Winnie
The awning should come with a couple of big L brackets and you can U bolt those on.
I just drilled into the rack.
My ARB came with a couple about a year back.
Winnie
Once I got the roof rack, this is how I mounted them by the four uprights.
24th July 2014, 12:16 PM
#18
Hi lads, the brackets in the image that Hodge posted are from Rhino. We do make L brackets that are designed to sandwich between the rack mount and the rack itself (this can be done with Rhino mounts as well). There are a range of options depending on vehicle and rack style, so I won't post a part number. Your best bet is to drop in to an ARB store/stockist and get sized up.
Any dramas, give us a shout.
David
ARB 4x4 Accessories Head Office
The Following 4 Users Say Thank You to ARB 4x4 Accessories For This Useful Post:
AB (24th July 2014), deanfurley (25th July 2014), MudRunnerTD (25th July 2014), Stropp (25th July 2014)
25th July 2014, 11:24 PM
#19
ARB 4x4 Accessories
David
Thats what i got Dave, Phil from St Peters ARB Sorted me out, i'll post a some pics when i mount it up over the weekend.
After calling into two other ARB dealers and talking to a 3rd one on the phone, i was kinda ready to give up, but then got on the phone to St Peters, and they sorted me out. i went to Artarmon, and it felt like the guy thought i was an annoyance, i told him they did do a bracket, and he assured me they didn't. 2 days later i have one in the back of the car.
31st July 2014, 06:08 PM
#20
Well i managed to get the ARB Bracket, for the awning, it's pretty good very happy with it.
I pushed it as close in as possible and it looks really clean. Expensive but $90 for the bracket, $20 for replacement nuts and bolts (316 stainless) + $15 for ratchet spanner (worth every penny with nylock nuts)
