Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Why does your car vibrate after giving it a lift
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
  2. The Following 19 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    93patrol (13th July 2014), AB (12th July 2014), Alitis007 (13th July 2014), Danyael (7th March 2020), doka404 (12th July 2014), firm351 (13th July 2014), GUDriver (19th May 2016), Hakan the Swede (8th July 2016), Hodge (12th July 2014), kamyar punisher (11th November 2014), mudnut (12th July 2014), MudRunnerTD (12th July 2014), mudski (12th July 2014), Parksy (12th July 2014), Patrol-Guy (12th October 2014), porkroll (25th September 2014), Robo (13th July 2014), rusty_nail (11th November 2014), threedogs (12th July 2014)
    Thanks Toddie.
    Everyone should watch this video and think about your tail shaft and uni joints. This is Very. Very Important! Check this out and have a look at yours.
    Very good Info, thanks Toddie.
    brisbane
    would double cardan joints eliminate the vibrations though ?
    Quote Originally Posted by megatexture View Post
    That's one of the reasons why guys with Shorties and big lifts have to fit a double cardan joint.
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Excellent video. Don't have this issue with CV's.
    IMO and should be taken with a grain of salt.
    brisbane
    I thought it was because having two joints makes it stronger due to less angle not the vibrations
  10. #8
    Certainly. Reducing the operating angle using the double Cardan relieves the drive train allot but is also reduces the vibration they get through it.
    I'm not sure that a better video could be produced to explain it. I was not aware of the oscillating nature of the I is when they are out of sinc. I did have a bit if vibration through the. GQ and adjusted the upper trailing arms to increase the pinion angle to match the gear box end and it made a huge difference. I am going to check whether the unis are lined up and sort that out too.
  11. #9
    On this subject how does one check that their tail shaft is in "phase"
  12. #10
    Quote Originally Posted by timmay556 View Post
    Match the uni joints at both ends. Sit the both either vertical or horizontal at the same time when fitting the tail shaft.
  13. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Parksy (13th July 2014), timmay556 (13th July 2014)
