18th July 2014, 11:01 AM
#111
Hardcore
Troy how is your car going now, transfer all fixed ?
Mat, you organising a trip ?
18th July 2014 11:01 AM
18th July 2014, 11:09 AM
#112
Its all apart atm and bit of a mystery whats causing the shudder and they are having trouble finding one with low ks for a transplant so might be looking at a rebuild as alot of the teeth have wear on them
18th July 2014, 11:35 AM
#113
Hardcore
Bugger, my guess was not your transfer causing the problem, so i hope im wrong.
Output bearings check out OK ?
18th July 2014, 11:56 AM
#114
megatexture
The park brake isn't holding on a touch is it? Has your rear diff ever been out?
18th July 2014, 11:57 AM
#115
04OFF
Yeah send me a message later on and I will try to remember to post it when I'm at home with the laptop.
18th July 2014, 05:32 PM
#116
nissannewby
Yea hes checked that and said its fine and will use it with the replacement case as they finnaly tracked down a 2010 with 100 km on it so at this point its just going to be a straight swap.
Also just to rule out the hubs, they will be gutted to be manual on/off but I had already locked them so doubt its them.
18th July 2014, 05:41 PM
#117
04OFF
You thought it was the hubs didnt you?
When I lay under the car driving I tracked it by sound and feel and it was definitely at the transfer, it felt like some one was hitting it with a hammer and sounded like bind up the a clunk as it releases presure.
18th July 2014, 10:06 PM
#118
Hardcore
megatexture
Well, not really, to be honest Troy I don't have a clue, thats why I kept out of it , from my loose memory of the description of the problem at the time, I just remember thinking shaft joints and diff sounded more likely suspect, I guess because from memory, it was a out of balance type of judder/vibration ? ,I guess a main bearing in the transfer could cause this, but to me I just thought else where.
Anyway, like I said, I don't know, and have never heard/felt it first hand , so anything I say is always a guess, I just hope im wrong, and it "is" the transfer, cos that means you will be out on the tracks with us soon.
I would really like it if you and Mat can make it out to LCMP
18th July 2014, 10:51 PM
#119
04OFF
There was a loud squeal that we had developed at the around the time this came about but that was a spacer for the rear diff, It was mashed up and squealing.
I'll be trying to make it mate don't worry about that!
19th July 2014, 08:46 AM
#120
Hardcore
Sounds like more excuses haha
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of themselves without that law is both.
For a wounded man shall say to his assailant,
'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honour.
