Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Differential rebuild GQ RB30 4.375 Help!
    Legendary dom14's Avatar
    38 Post(s)
    Hey guys,
    Can I clean the diff centre unit(spider gear, clutch plate assembly) with degreaser and flush out any gunk?
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    38 Post(s)
    Few more photos.
    Soon after dismantling and cleaning the diff centre assembly off the diff centre housing.
    It only took couple of not so hard hits with a rubber mallet(on the top rod end of the pinion gear) to get the pinion gear off the
    pinion bearing.
    Cheetah Outreach
  4. #13
    38 Post(s)
    These are some closeup pictures of the parts of the pinion gear, pinion bearings and races.
    Cheetah Outreach
  5. #14
    38 Post(s)
    These three pictures show the carrier bearing preload adjusting shims & their locking retainer mechanism.
    These pictures were taken before I removed the pinion gear off the diff centre housing. This is a late post of these pictures.
    Cheetah Outreach
  6. The Following User Says Thank You to dom14 For This Useful Post:
    Danyael (21st January 2020)
  7. #15
    Jan 2019
    I've just went through it and this is a fairly good documentation of a dissection;-) In my opinion those bearings were no good. How did You end up with this project? Did You fix it or have You changed the whole thing?
  8. #16
    Sorry, mate. Dom has been gone for a very long time, so don't expect an answer.
  9. The Following User Says Thank You to mudnut For This Useful Post:
    rusty_nail (21st January 2020)
