Page 14 of 17 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 166
Thread: Home made tools...
  1. #131
    109 Post(s)
    This thing is so good, but I had never heard of it, before.
    https://www.youtube.com/watch?v=Cd2LY857oTY
    He mentioned boatbuilders in this clip but made a 2D shape. It was impressive how it worked, but I'd like to see how 3D objects can be plotted with this method, if at all.
    How to 3D this concept?
    324 Post(s)
    I reckon you would have to make all sides this way and build the model then measure and or use a sliding bevel to get the 3D angles.
  4. #133
    Expert Mickhead's Avatar
    Oct 2019
    Looks great for straight lines, thinking it will not be great if you got some curves in your shape
  5. #134
    Quote Originally Posted by Mickhead View Post
    That's where you just get as many datums as you think would be required along the curved edges
    Posting bollox using Tapatalk
  6. The Following 4 Users Say Thank You to Clunk For This Useful Post:
    Cremulator (7th September 2021), Mickhead (13th September 2021), MudRunnerTD (13th September 2021), rusty_nail (7th September 2021)
  7. #135
    i did try it, it works well. was pretty impressed.
  8. The Following User Says Thank You to rusty_nail For This Useful Post:
  9. #136
    I was thinking about this, and came up with a solution for 3D. If you could get an old transistor radio extendable antenna, you could mount it on the tick stick. When you make the base outline, swivel and extend the antenna to the 3D point. Measure the angle and length and write it in that traced outline. Simples.
  10. #137
    109 Post(s)
    I get that, I really do. But how do you then cut it from virgin material? You can't just get around with vertival cuts, it will be all wrong. It needs to be cut at respective angles through the material. I can get no further than that though. Plenty of better brains around than mine!
  11. #138
    Oct 2019
    Try that at home and let me know how it goes I would not have te patience 🤪
  12. #139
    324 Post(s)
    It would be pretty easy mate. Using the tick stick and just ploy the curve . Yes you would have to join the dots but with 6 or 8 plots you'd be done. Infact use the full tick stick for the important corners and just the head only along the curve line. This would make very light work of it.
  13. #140
