Page 2 of 17 FirstFirst 123412 ... LastLast
Results 11 to 20 of 166
Thread: Home made tools...
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Some for flat steel bending/shaping
    1999 GU 4500 dual fuel
    Il dado è tratto
  2. The Following User Says Thank You to NP99 For This Useful Post:
    blocko05 (25th July 2015)
    Heres an easy bending jig to make , Set the jaws to the correct width heat your steel and go for it,
    Will bend ,flat ,round, square you name it
    All it is is two pieces of angle iron with two 19mm rods welded to them
    I have heaps so I'll put more later
  5. The Following 3 Users Say Thank You to threedogs For This Useful Post:
    blocko05 (25th July 2015), mudnut (10th November 2014), NP99 (10th November 2014)
  6. #13
    A simple one I posted on another thread, for vacuum cleaning the dirt, sand and oil from around the spark plugs, before you undo them. For the RB30 spark plugs, the inner diameter is 20mm and the outer 23mm. I used electrical tape as a seal for the vacuum pipe.
  7. #14
    If you have trouble using the small tubes of silicon for gaskets, I have found a a way to make it easy.
    Keep an old silicon cartridge with the plastic plunger removed and the threaded bit cut off flush with the end.
    Cut it to a length that allows you to push the tube's nozzle through the hole. Use a pair of pliers to fold the end of the tube enough to allow it to slide freely once you have placed it in the cartridge.
    Adjust the plunger of the silicon gun to hold the tube.
    Be careful not to force the trigger too hard or you may rupture the tube, especially if the nozzle hole is very small.
  8. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    dom14 (29th July 2017), MudRunnerTD (17th February 2021), PeeBee (22nd June 2017)
  9. #15
    ... works a treat in the Bathroom for KY Jelly, Colgate Toothpaste and Hemorrhoid Cream tubes as well.
    Pays to ALWAYS double check what is loaded in the Gun before use tho and it is considered poor etiquette when visiting others to ask why they prefer the longer nozzles
    I'll see if I can post up some Vids on correct techniques for use for you blokes to check out
  10. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    mudnut (22nd June 2017), MudRunnerTD (17th February 2021)
  11. #16
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    It is difficult to video when using the product(s). I find it works better if you fix the camera on a stand and have another person as a model while you do the injecting. just sayin.
  12. The Following User Says Thank You to 4bye4 For This Useful Post:
    the evil twin (22nd June 2017)
  13. #17
    What ailment do you suffer to need to use all those ingredients at the same time?
  14. #18
    Dementia, Alzheimers and ... errr.... ummm... what ingredients?
    Oh, those ingredients, well, when used in the correct order of KY, Preparation H and Colgate you can painlessly cure your 'roids and with regular use have an arsehole up to 3 shades whiter
  15. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    dom14 (21st July 2017), mudnut (22nd June 2017), PeeBee (22nd June 2017)
  16. #19
    Got a piece 90mm bright steel machined up to make a drift for the front hub bearing seals. Only $15 dollars at a small engineering shop.
  17. #20
    Couldn't get Easy Outs because of Covid Lockdown, so I used an Allen key that was just slightly larger than the hole drilled through the broken bolt. Just make sure you hold the key straight as you tap it in with a hammer.
    Edit: I think Easy Outs and such are made of steel that can be drilled out if they break. A broken allen key would require an especially hard drill.
  18. The Following User Says Thank You to mudnut For This Useful Post:
