Page 9 of 17 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 166
Thread: Home made tools...
  1. #81
    109 Post(s)
    Yes i have a cast plate on the grill and it's too hot. I will invest in the cast plate to suit for sure.
    I actually don't get this at all Daz!
  2. The Following User Says Thank You to Plasnart For This Useful Post:
    MB (26th April 2021)
    472 Post(s)
    I think what Daz might mean Plassy is that with a flat fry pan directly on top of the new age wind shields the heat is too centralised causing uneven cooking.
    Unlike traditional camping cooktops these rippers don’t have side wind wings but special circular shields around each jet thingymebob.
    Does allow you to put huge water/yabby pots and woks atop exceeding the cookers width but frypans really struggle to keep to a low and slow even heat.
    The raised BBQ OEM plate still finds two ‘hot spots’ above each burner but nowhere near as bad as a capped frypan if any of that makes sense
    Great Cookers
  5. #83
    109 Post(s)
    Great Cookers
    Nope, didn't feel anything doc. Might need to see yours in action to understand.
    Been doing a bit of Rooftop eyeballing juggling thinking and getting warmed for a quick combo far east revisit/new venture bush blast before the SC's kick in.
    You'll understand. I'm speaking MB.
  6. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    Cremulator (26th April 2021), MB (26th April 2021)
  7. #84
    472 Post(s)
    Copy that.......Roger wants to run ropes for me’s
  8. #85
    109 Post(s)
    Umm yeah I'll call ya. Can speak MB 101 level but not fluent!
  9. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    MB (26th April 2021), MudRunnerTD (27th April 2021)
  10. #86
    Yeah so my plate sits straight in the wind shield. As MB stated it causes a real Hot spot and everything burns. The plate made for the unit has feet on it that sit the plate about 10mm to 15mm up off the shield allowing the heat to be a broader spread. In Tassie I had a wire trivet that I trialed under the plate to lift ans it helped a bit.
    They are a waist of time though if you dont also do the action clean detailed in the YT links. The factory Low setting would at best be a High Simmer. Once rhe heat is in these things will cook your dinner on Low.
  11. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (27th April 2021), Plasnart (27th April 2021)
  12. #87
    Apr 2021
    Brazil
    Steering wheel puller
    Build this ugly thing to pull the steering wheel of my Y60. It did the job, so I can't complain.
  13. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    MB (25th May 2021), mudnut (25th May 2021)
  14. #88
    Haha! I reckon you could use that when doing a Brake pad change too mate, thought that was what it was. Perfect for pushing that piston back.
  15. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (25th May 2021)
  16. #89
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I saw this homemade tools thread and thought I’d post some pics of a sheet bender I made some weeks ago. I had no special reason to build it apart from the fact that I always wanted one and, after watching a few YT vids on DIY units and seeing as I had most of what I needed anyway, I decided to get into it.
    It’s almost all done with DC TIG. Getting in some practice on my new Unimig Razor 200 AC/DC.
    As luck would have it, I had just recently installed a diesel heater in our caravan and wanted to protect the fragile hot air tubing so I made a tunnel from 1.6mm tread plate ally all bent with this bender.
    I might get around to painting it one day..
    John
  17. The Following 5 Users Say Thank You to jff45 For This Useful Post:
    Cremulator (25th May 2021), MB (25th May 2021), Mickhead (26th May 2021), MudRunnerTD (25th June 2021), Touses (26th May 2021)
  18. #90
    472 Post(s)
    Magnificent John Mate!
    Keep them coming pretty please, truly inspiring stuff, Legendary
  19. The Following 2 Users Say Thank You to MB For This Useful Post:
    Cremulator (25th May 2021), jff45 (25th May 2021)
