Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 166
Thread: Home made tools...
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Home made tools...
    http://youtu.be/QKhRfSMd5WY
    A handy bush tool vid I found...
    1999 GU 4500 dual fuel
    Il dado è tratto
  2. The Following User Says Thank You to NP99 For This Useful Post:
    dom14 (21st July 2017)
    Apr 2013
    yeh ...I made one of them after seeing that video about a year ago to try on wishbones....a little bit of mucking around elsewhere but certainly works if no press available.
    the one thing wrong with middle age ...is knowing you will grow out of it !
    Good old Roothy had plenty of these tricks, being an old bushie from way back
    Feb 2013
    Broadford VIC
    It's in line with a suggestion I made on the forum a while back re loaning tools out. If enough of these home variants were made we could loan out to a select few......maybe!!!
    Il dado è tratto
    Here's a flange spanner I made, to prevent bending the studs on a transfer case. And a drift for the radius arm bushes, I had machined up for $10, (I provided the steel). I also made a hand vacuum pump by reversing the rubber washers in an old bike pump.
  8. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    dom14 (21st July 2017), NP99 (16th July 2014), threedogs (10th November 2014)
  9. #6
    Feb 2013
    Broadford VIC
    Il dado è tratto
  10. #7
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    I have a few of my homemade tools, i'll have a dig around
  11. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
    NP99 (17th July 2014)
  12. #8
    It seems that sometimes you need three hands, to re-assemble some small electric motors. Here is an easy to make tool for holding carbon brushes in the correct position, so it is easy to fit them over the commutator.
    Measure the distance that the brushes need to be held, drill a hole in a piece of wood, big enough to accommodate the rotor shaft and / or bearing. Nail some wire brads or nails in a pattern around the hole that will hold the brushes, without snagging on the brush holder assembly.
    Use pliers to snip off the nail heads, so it is easy to slide the assembly off after the commutator has been slid into place.
    Place the brush holder over the tool and slide the brushes back, so they are held by the nails. Slip the commutator in, then lift both the commutator and brush holder off the tool.
  13. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    dom14 (21st July 2017), NP99 (17th July 2014)
  14. #9
    Feb 2013
    Broadford VIC
    I found this on the www. Metal bending machine.....
    Il dado è tratto
  15. The Following 4 Users Say Thank You to NP99 For This Useful Post:
    dom14 (21st July 2017), mudnut (3rd August 2014), threedogs (10th November 2014), Tip12345 (24th February 2021)
  16. #10
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    Quote Originally Posted by NP99 View Post
    Now thats a neat idea. same principle as the hydraulic pipe benders but you could probably roll rings if you could some how feed the steel in.
    I have a few bits and pieces lying around that I've turned up on the lathe. I'll see what I can find in my travels.
