7th July 2014, 08:51 AM
Need advice
Hi guys im looking at a 91 gq rb30 5 speed on 33's it needs a carby tune, fuel pump wired up,rear diff opinion bearing just wondering how much it cost to do the rear diff and how do the rb30 engines go cheers
7th July 2014 08:51 AM
7th July 2014, 08:54 AM
Pinion not opinion phone changed it
15th July 2014, 07:37 PM
it wont be quick running 33 if the RB30 is stock - carby. Replacement motors are cheap
It is still a great 4wd.
I had a carby rb30 in a Mk, when I upgraded - I went to the TB42 - they are chaulk and cheese.
Why does it need the fuel pump wired up?
The carby probally needs a kit. (around $70 from bursons)
The question is.
Can you do the work your self - do do you need to get a mechanic to do it.
How do you know its the pinon playing up - whats the issue. It might be easier to replace the center or do a complete diff swap - but you still need to pull both axles etc.
1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
And its Toooooooo High for the Ball & chain
17th July 2014, 09:22 PM
Its ok I didn't end up buying it was only asking cause it was $1000 I didn't even get to go look at it or ask questions
