Results 1 to 9 of 9
Thread: auto problem
    Jun 2014
    auto problem
    Hi, my tb42e auto is playing up. It takes a while to select drive and reverse but can select 1st 2nd fine. Have to take off in 2nd and slap it into drive or stall it up for it to select. Anyone had this problem before? It's a very weird fault. Once it's been driven for a while it selects fine. Any help greatly appreciated
    When was the tranny last serviced, fresh oil might work wonders
    Jun 2014
    New oil and oil filter already done. I did that as I thought maybe the oil had lost its viscosity and wasn't creating enough pressure, however this hasn't changed a thing.
    175 Post(s)
    If once it's been driven for a while, it's fine... To me that sounds like oil or low on oil ? Have you checked that?
    Patrol Freak jff45's Avatar
    May 2012
    Morayfield, QLD
    13 Post(s)
    I'd start with dropping the pan and washing out the gauze filter and flushing it completely with some good synthetic fluid.
    Once you get the pan off you'll see by the amount of debris in there if it's overhaul time or not..
    John
  7. #6
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Hi there, I have moved this thread to the gearbox section of the forum and deleted your other thread, please only post up the question in one thread.
    Could be a range of things, there is a procedure list in the workshop manual for testing the auto.
    It could be a faulty temp sensor.
    I would suggest finding a good auto trans specialist and not just a mechanic 2 have a look at it.
  8. #7
    Agree with NissanGQ4.2......... I was thinking transmission fluid but could other things that we could only guess at. No point trying to guess when it come to transmissions, take it to a transmission specialist and let them diagnose the fault properly
  9. #8
    Patrol Freak kevin07's Avatar
    georges hall
    the only time that happened to me was when the leaky old hydromatic on the eh ran low on oil and stuffed the gearbox same things happened, so being the bearer I don't think things sound good.
    07 crd,,bridgestone 697lt, 2.75 buedesert ex, SOLD theres a lot of my blood, sweat and money in that troll.
    92 gq ti tb42efi my brothers gq extractors dual batteries brake controller uhf alloy bullbar SOLD with a heavy heart but gone to a nice young fella
    13 y62 the beast that burbles
  10. #9
    Patrol Freak Sherro's Avatar
    Feb 2014
    Logan, QLD
    2 Post(s)
    Oil level or hard seals can cause this check oil with engine running in park if level is good might be hard seals and only a rebuild can fix that might have to drop it into an auto specialist over night for them to diagnose it properly.
