24th June 2014, 12:14 AM
GU Patrol Rock Sliders Series 1,2,3 Xtreme Duty- Unique 3 Rail design
http://www.ebay.com.au/itm/GU-Patrol...7a22a0c&_uhb=1
Up for auction Pick Up ONLY
These Have been tested out and cleaned up with a fresh powder coat in satin black
Will come with new set of bolts M12 8.8, nylock nuts and Drilling template for front leg
Unique 3 Rail designed for maximum ground clearance off sills and
will only loose 30-35mm off sill seam, unlike 50-60mm from other designs
These are an extremely strong set of sliders So if your rough on your gear these are for you ..
They have been made and designed by myself a trade qualified Boilermaker
They are made from
Inner rail is 2" x 4mm wall DOM hydraulic tube
Mid & outer rail is 1 1/2" x 4mm DOM hydraulic tube
Legs are 10mm plate
Chassis clamps are 8mm plate
Inner to midrail joiners are 16mm plate
1999 GU 4500 dual fuel
Il dado è tratto
The Following User Says Thank You to NP99 For This Useful Post:
24th June 2014 12:14 AM
