25th June 2014, 05:37 PM
Im screwed, what size do I need
Afternoon all,
I am hoping someone out there can tell me what size screw hole, and/ or screw this is. I have two holes in the right side engine bay, near the large set of fuses are that I want to use to mount my fuse box into. The screws that support the fuel filter fit nicely into these but I do not know what size I need to get.
If I could get some assistance with this please, that would be super.
Many Thanks
Adam
2001 GU II - 3.0TD Auto. ARB Bullbar - Runva 11XP Winch - NADed with Boost & EGT gauges - OME 2in Lift - Manta 3in - Dual Battery - Spotties & LED Lightbar - Uniden 80ch UHF - Rear Drawers & Engel Fridge - 3/4 Steel cage
Car goes vroom
25th June 2014 05:37 PM
25th June 2014, 05:41 PM
Do you mean bolts??? hard to say as I dont have one but M8 ???? actually looks more like M6
Just take one out from somewhere not vital and go to you local bolt bloke.
The Following User Says Thank You to Bloodyaussie For This Useful Post:
jackwalks (25th June 2014)
Mate in a similar situation what I done, is visit the nut 'n bolt shop, and just asked the bloke if I can try some guess sizes till I found one that fits, then bought them.
25th June 2014, 05:45 PM
Bloodyaussie
Cheers mate, yes bolts/ screws same but different My topic heading would not have sounded the same if I had: Im bolted.
Hodge
I will try that over the weekend, many thanks for the idea
Car goes vroom
The Following User Says Thank You to jackwalks For This Useful Post:
25th June 2014, 06:42 PM
Moderator
The bolts that hold the fuel filter on a TD42 are 8mm x 1.25.
I stripped one yesterday and had to retap it.
Check out my Toy -->
Rogue Dung Beetle
The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
Bloodyaussie (25th June 2014), jackwalks (25th June 2014), taslucas (25th June 2014)
25th June 2014, 07:21 PM
At the risk of being pedantic, a 'set screw' is a bolt that has no shank i.e. the thread goes right up to the head.
Yeah, I know, we all call them bolts anyway..
John
The Following User Says Thank You to jff45 For This Useful Post:
25th June 2014, 07:43 PM
Muddy,
strippers are good, screws are good but where you've just been definitely aint
Be strong
Col
