Results 1 to 10 of 11
Thread: Brake upgardes for Cummins 4.5???
    May 2015
    Ballina, NSW
    The patrol (GUIII Y61 2002) is booked for Cummins 4.5 conversion in April 23, what's peoples thoughts on brake upgrades? Hydro-boost or aftermarket upgrades etc....
    It's set up to be a tourer / caravan / boat
    FYI i have no idea hence the question hehehehe....
    Cheers Janno
    194 Post(s)
    I went the Willwood brake upgrade path. It gives 6 piston calipers on the front and 4 on the rear. You need to upgrade the master and booster as well for best effect. Its a complete kit, operating at 'normal' pressures. The Hydroboost offer a good upgrade as well, in my mind a bit more complicated, but they stop really well with higher clamp pressures. I went the Willwood as wanted to not be burning through pads as can happen with the Hydrobooster if you start standing on it really hard. I find the Willwoods are fine, you must run at least a 17" rim though. The kit ends up being twice that of the hydroboost so a bit to think about. There are a couple of guys running the Hydroboost on here, maybe they will chime in, also some who have gone the TB48 route.
  4. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    Janno (1st October 2022), jff45 (2nd October 2022), MB (1st October 2022), mihit (1st October 2022)
    472 Post(s)
    Quote Originally Posted by Janno View Post
    Cheers Janno
    G’day Janno Mate,
    Apologies for the snippet cut&paste above.
    Only my nuffy opinion but please do discuss full and final usage needs with your engineer to achieve not only little Cummins donk transfer but your overall GCM ( Gross Combined Mass) future towing needs
    Jun 2018
    24 Post(s)
    I put the Marks hydraulic brake booster on my GU III 2004 TD42Ti earlier this year.
    My thinking was to do the booster first, then if it required it, I could upgrade rotors and pads.
    The improvement with just the hydraulic brake booster was significant, it's really impressive, and I haven't felt the need to change the factory rotors/pads I have on there.
    I'm running 285/75R16 tyres.
  7. The Following 4 Users Say Thank You to Cremulator For This Useful Post:
    Hodge (2nd October 2022), jff45 (2nd October 2022), MB (3rd October 2022), PeeBee (2nd October 2022)
  8. #5
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    I initially went with slotted DBA rotors and those grossly overpriced ECB Yellowstuff pads but still wasn't happy so I did the hydroboost and now I'm much more confident following others a little more closely so I don't get the usual slalomers cutting in front of me. Also, at 77, I don't have the same reflexes so the hydroboost helps there as well.
    If your budget allows, why not do the Cummins, Wilwood and hydroboost upgrades together?
    In for a penny...
    John
  9. The Following User Says Thank You to jff45 For This Useful Post:
  10. #6
    194 Post(s)
    In for a penny...
    Now that would be a combo for sure!
  11. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
  12. #7
    May 2015
    Ballina, NSW
    Thanks, good advise. Gold Coast Patrols are doing the conversion. They have only done QLD 4.5 Cummins although he uses another certifier for NSW. I will try and chat with him directly. Only needed a hydra boost for QLD.
    Janno
  13. #8
    May 2015
    Ballina, NSW
    thanks John, but budget is blown with the Cummins hehehehe
  14. #9
    Apr 2021
    Brazil
    I recon the OP could execute some front flip maneuvers with that.
  15. #10
    472 Post(s)
    Janno
    Agreed pissed, it would suck Massive Dick to be told an upgrade (heavier front end) is un achievable in Straya :-(….downgraded to the likes of a TD42T (workable) manual 3.5T rear barn door VIN sticker
