Page 7 of 23 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 230
Thread: RB30 Facts, Figures and Helpful Hints
  1. #61
    80 Post(s)
    Quote Originally Posted by pat in a troll View Post
    don't know if they've already been posted, but I have RB30 ECCS information from the factory R31 skyline service manual if it's not on here already (as well as engine information like torque figures etc.)
    Go for it Pat. There are a lot of
    modified RB30s out there.
    If we find the thread gets
    too big, we can always edit
    it and add links to sub threads.
    Jan 2015
    ok i'll get busy getting images for the pages.
  4. The Following 2 Users Say Thank You to pat in a troll For This Useful Post:
    dom14 (4th July 2015), mudnut (4th July 2015)
  5. #63
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Hi blokes,
    Following on from the info above I might seem like a but of a dinosaur here, but I have a couple of quick questions about my RB30 patrol, hopefully someone can help.
    I thought of going EFI, turbo etc, and still might, or do an engine transplant later when funds permit.
    In the meantime, I discovered my patrol still has the honeycomb heater insert, so that's coming out, and my carb looks dirty as heck, so I'll service that too. When removing the honeycomb element, did others also remove the can in the other carb throat? I've read it is for fuel distribution and should be left in place?
    I'm also going to see about a better exhaust as while I have extractors, the exhaust is very quiet and is probably a factory unit (or equivalent replacement), so might be a little restrictive.
    Who knows, I might even be happy with it after the changes, since it only feels like it needs a little more power. I do like the simple set up.
    Another question, I have a small round device above my brake booster on the firewall, with two wires, and a vacuum hose coming out of it, (first photo), what is this for and should the vacuum line be connected to the front of a round device on the front left of the carb? (Second photo).
    Thanks all.
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
  6. #64
    80 Post(s)
    Definitely leave the deflector
    in the throat of the manifold.
    If you do take the heater grid
    out, it is best to have the stove
    pipe assembly operating correctly
    otherwise the engine will struggle
    when cold.
    The device you described is
    the FICD which operates
    the fast idle actuator when
    the aircon is working. It
    is dealt with
    earlier in the thread.
  7. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    dom14 (10th August 2015), Patrol'n (20th July 2015)
  8. #65
    Oct 2014
    WA
    when cold.
    is dealt with
    Hi Mudnut, I should have looked harder at this thread first, it's all there, thanks very much mate.
    I see you replaced your alternator, did you fit another 60 amp one, or go for an upgrade? I've seen 80 amp ones available to fit, but I wonder about the original wiring handling extra current.
    Here in WA it doesn't get that cold that often, but if it struggles in the cold I'll reinstate the stove pipe as you suggest. I'll have to weld a pipe fitting onto the extractors, since they don't have one.
  9. #66
    80 Post(s)
    If you haven't
    got the original heat
    collector plate, it would be
    easy to make one.
    It would also be fairly easy
    to attach it with stainless
    steel hose clamps.
    I believe the alternator
    I acquired locally is
    the same as what
    Patrolapart have on offer.
  10. #67
    Oct 2014
    WA
    Ok, I've had a look at the patrolapart alternator, think I might have to get one, so can I assume you've had no wiring issues, fuses blowing etc? And did you notice any power drop from the engine driving a more powerful alternator?
  11. #68
    80 Post(s)
    None at all, because
    I have not added any
    accessories, so the
    power required to
    drive the alternator
    is the same.
  12. The Following User Says Thank You to mudnut For This Useful Post:
  13. #69
    Jul 2014
    6 Post(s)
    If upgrading to a higher output alternator, I would definitely be running a higher capacity wire from the alternator to the battery.
  14. The Following 2 Users Say Thank You to Throbbinhood For This Useful Post:
    mudnut (20th July 2015), Patrol'n (20th July 2015)
  15. #70
    Oct 2014
    WA
    Point taken about the accessories, I guess it's because I may add a couple of extra things and therefore may require more from the alternator that I was asking, more of a future proofing line of thought.
