19th June 2014, 03:19 AM
The Broken N Bent thread, with fixes if possible.
The Following 3 Users Say Thank You to sil3nt_dr3ams For This Useful Post:
Bloodyaussie (19th June 2014), Clunk (19th June 2014), NissanGQ4.2 (19th June 2014)
19th June 2014 03:19 AM
19th June 2014, 07:49 AM
I should do that to mine before I bend them lol
19th June 2014, 07:55 AM
Been meaning to ask someone about my ARB side step/side protection bars... the step part of them are bowed from using them as sliders and to pivot on and want to take them off and clean straighten and paint...
Now how would I go about getting them straightened ??????
19th June 2014, 08:05 AM
The 747
Bloodyaussie
Hammer. Really big hammer.
19th June 2014, 08:36 AM
@ BA use an up right hydraulic press will need to blokes press past centre then relax.
Should be easy enough or make a jig using your hydraulic juack
@ SD Nice laminating work BTW
Bloodyaussie
Upload some pics mate,
19th June 2014, 08:40 AM
threedogs
Lol cheers,
Depending on how its bent it can be shitload easier to notch the steal then weld it back up.
The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
threedogs (19th June 2014)
19th June 2014, 08:44 AM
You can see in this pic what I mean.... I will be removing them as I want to also fix the bullbar
19th June 2014, 08:52 AM
Could cut with fine disc then re weld when straight
19th June 2014, 08:53 AM
Side steps I would heat up clamping them down to a nice metal H or I beam or something straight and a lot stronger than the pipe.
