Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: 35" on GQ what lift kit to use
    Jun 2014
    Hi guys,
    New to 4x4 scene, I have a GQ LWB wagon that I am about to mod, I would like to run 35" tyres, what lift kit would I need to give it clearance? Thinking 4" all round with no body lift.
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    hey mate jump over to the intro and put a post in there!
    As for the lift on 35's, this a question I will never understand, If the tyre wont fit in the guard now on full flex it's not going to fit in the guard no matter what lift! I run 35's and cut both front and rear guards.
    GQ Snorkle Lockers front n rear
    Hardcore healy's Avatar
    south east melbourne victoria
    I run a 2" lift &2" bodylift works great with 35s
    IF ITS NOT BROKEN IT MUST BE A PATROL
    Expert makeitfit's Avatar
    Aug 2011
    Aberporth beach, west Wales, UK
    Yep 35s here too . Simple 2" susp lift and 2" body lift works for me
    Y60 Patrol 4.2 d SWB in puke green
    2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
    Jun 2014
    So a 4" susp lift will be the same as 2" body + 2" susp?
    43 Post(s)
    You'll have to really watch your compression length and extend the bump stops to suit.
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by omy View Post
    Nah not the same. Suspension lift will increase the distance between the axle and chassis whereas a body lift increases the distance between the chassis and the body.
    Hello from Under Down Under!
    Jun 2014
    What would I need to complete a 4" lift front and 5" lift rear? I want to go higher on the rear as I will be adding a long range Tank and two spares tyres!
  10. #9
    Oct 2011
    Essendon
    Big difference between 2 inch and 4 inch lift in what is needed.....
    For 2 inch, springs and shocks is pretty much it.....
    For 4 inch, adjustable panhards, swaybar extensions, springs, shocks, drag link (I think), caster correction (drop boxes, bushes, plates) extended brake lines and more.....
    Also, you don't want 4 inch front and 5 inch rear, you want properly chosen 4 inch springs all round, designed to carry the weight you expect to have on board.
    Sent from my iPhone using Forum Runner
  11. #10
    Jun 2014
    So 4" all round with heavy duty springs in the rear?
