Page 62 of 69 FirstFirst ... 12526061626364 ... LastLast
Results 611 to 620 of 683
Thread: Jay see 1997 GU build up
  1. #611
    49 Post(s)
    Not sure re the battery mate, but if you can put it on stands and lay tyres on their side, avoids a flat spot on them.
    Got flat spots on the Commodore after sitting for awhile, a drive smoothed them out, don't know if I'll get the same result with the bigger tyres.. stands might be the way to go..
  2. The Following User Says Thank You to jay see For This Useful Post:
    rusty_nail (11th July 2022)
    49 Post(s)
    Yeah disconnect negative battery terminal (s) Give it a drive and or hook up to charger every so often . . .
    Trols parked in the sun, will the 110w panel be enough to trickle the batteries, it runs a dual sensing isolator..
  5. #613
    461 Post(s)
    That will work. I used a 10W panel for a long time, which even worked, until I finally bought a decent charger.
    jay see (12th July 2022), Rossco (12th July 2022)
  7. #614
    49 Post(s)
    Something that I've been wanting to do for a while was replace the carpet.
    Well that day has arrived. While I'm at it I'm cleaning up the mess under the dash and rewiring everything from the aux battery.
    It was all running under the carpet and up the dash behind the radio, then when I installed the roof console being lazy I put connecters and extended the wires under the dash and up the A pillar to the roof console.
    Now it's all going from the aux battery to the centre pillar and to the roof console.
  8. The Following 6 Users Say Thank You to jay see For This Useful Post:
    BrazilianY60 (23rd September 2022), Cremulator (24th September 2022), MB (23rd September 2022), mudski (26th September 2022), PeeBee (23rd September 2022), Rossco (23rd September 2022)
  9. #615
    49 Post(s)
    Anyone seen or used these?
    Or what are you using to tidy up the positive terminal..
    https://www.ebay.com.au/itm/39372448...mis&media=COPY
  10. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (25th September 2022), mudnut (24th September 2022)
  11. #616
    There are insulated posts you can bolt on as well as bus bar types. Either gets the mess away from the battery post.
  12. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    jay see (25th September 2022), MB (25th September 2022), MudRunnerTD (25th September 2022)
  13. #617
    49 Post(s)
    Carpet has been ordered, decided to go with a charcoal colour I'll also get some decent mats maybe the deep rubber ones.
    Progress shots..
  14. The Following 4 Users Say Thank You to jay see For This Useful Post:
    Cremulator (25th September 2022), MB (25th September 2022), mudnut (25th September 2022), MudRunnerTD (25th September 2022)
  15. #618
    Looking good John,
    The remote Pos+ post Newby mentions are a bit of a winner.
    Consider a subfuse block to distribute the load rather than just a bulk number of supplies. A Narva style fuse block for the win.
    Assuming your using the narrative block inside the car then a single 50amp wire running off a Midi Fuse at the Battery would be ideal.
    Also note, Jaycar sell a 15amp rated 7 core trailer wire which could also be handy for colour coded sheathed wire up the A Pillar. Anything that needs bigger just switch through a relay anyway so the switching circuit in the 7 core switching the relay for the win.
  16. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    jay see (25th September 2022), Rossco (25th September 2022)
  17. #619
    Something like this inside the car and just a single supply off the battery fused at the terminal to the positive post on the box then fused again with appropriate size fuses to each load.
    https://www.ebay.com.au/itm/28430048...mis&media=COPY
  18. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  19. #620
    49 Post(s)
    Looking good John,
    I've ready have 10amp trailer wire running from the rear to the centre console to power up a couple of USB sockets. I'm using the rest for the roof console..
    Like this.
    All hidden when the seat is up.
  20. The Following User Says Thank You to jay see For This Useful Post:
