15th December 2019, 07:43 PM
#441
Sorry to gatecrash JaySee.
@Ben-e-boy Whats your thoughts on them Autoreset breakers, from Jaycar from example?
Where would you apply them ( if at all) , instead of your regular reset-able breakers?
https://www.jaycar.com.au/chassis-mo...12vdc/p/SF4102
I have 2 in 2 different circuits. Each circuit also has a fuse with same rating as the breaker (30A).
And I've tested them with current and direct to ground contact and they trip instantly, and kick back in when fault clears. Fuse does not blow, these breakers trip faster than the fuse-out.
15th December 2019 07:43 PM
15th December 2019, 09:15 PM
#442
Smart like tractor
Hodge
I'm not the biggest fan. If stuff is tripping out, its doing it for a reason. Even at work we generally dont auto reset anything. There is always the possibility of it frequently trying to close in on a fault without anyone realizing until something is completly rooted.
If I was to use one it'll be on a compressor or something not regularly used, but worked hard when it is. If for whatever reason you need to pump up the tyres of multiple rigs and work it pretty hard it'll trip when its had enough and reset when it's good and ready
96 GQ coil/Cab
08 G6eT
Hodge (15th December 2019)
17th December 2019, 06:47 PM
#443
How much current you can continuously run through a cable depends on 1. Is it cu or al. 2. What is its cross sectional area. 3. How is it routed? Eg.Under the carpet? 4. What material is the insulation made of?
Look at the Olex cable handbook.
Personally if I had 4ga cable running in my car protected by a 120A breaker, I would not stress unless I was pulling 120A thru it for hours on end.On a hot day.
But that is my opinion, make your own mind up.
15th March 2020, 01:05 AM
#444
Next little project is to permanently fit this.
The $5 shovel will live in the back of the patrol.
The Following User Says Thank You to jay see For This Useful Post:
21st March 2020, 02:38 PM
#445
The Following 4 Users Say Thank You to jay see For This Useful Post:
Cremulator (21st March 2020), mudnut (21st March 2020), mudski (21st March 2020), Rossco (21st March 2020)
22nd March 2020, 04:50 PM
#446
Cremulator (22nd March 2020)
22nd March 2020, 06:42 PM
#447
Daily Lurker
jay see
looking great mate, i had the same setup in my patrol. fyi, under the fridge there are some grub screws for permanent mounting. not sure if your design allows for access to those screw holes but one thing i did notice is the seam between the top and bottom part of the fridge started to seperate when i had the strap firmly tightened.
edit: i can see yours is already separating in the last pic.
The Following User Says Thank You to rusty_nail For This Useful Post:
jay see (22nd March 2020)
22nd March 2020, 11:26 PM
#448
rusty_nail
Thanks Nic. What fridge have you got. I had a good look underneath when I got it because that's how I wanted to fit it, but didn't see any screws at all. I might see if I can get some 10-20mm thick form from work and sit it between the plate and the fridge. Maybe that way I can back off the strap a little.
23rd March 2020, 08:57 PM
#449
Daily Lurker
jay see
Same one mate, cdf11 I think. Now that I think of it i probably just screwed into the the bottom of it. I'll have a look underneath to clarify bud
Sent from my Armor 5S using Tapatalk
jay see (23rd March 2020)
24th March 2020, 07:58 AM
#450
I'm a bit hesitant to do that.
