Page 58 of 69 FirstFirst ... 848565758596068 ... LastLast
Results 571 to 580 of 684
Thread: Jay see 1997 GU build up
  1. #571
    Expert Mickhead's Avatar
    Oct 2019
    I have a kings 120 watt solar panel on the roof running thru a MPPT kings controller. Supacentre is not bullshitting their specs like a lot of ebay sellers, it is 120 watts and it is MPPT and it is a fair price. Solar panels… 1 square metre of direct sun light = 1000 watts. At 18% efficiency a typical 1 x1 metre solar panel will max out at 180 watts. Remember this when you buy off ebay.
    My kings setup runs my second shitty lead acid under bonnet battery with VSR which powers a crappy aldi 40 lt fridge all year round, with room to spare for the occasional travel buddy morning tea. Weekday driven about 50k to work and back😀
  2. The Following User Says Thank You to Mickhead For This Useful Post:
    jay see (20th January 2022)
    194 Post(s)
    How do you validate these numbers? Solar density across Australia varies from 300 - 600w/m2 density from what I understand, and the 1000w/m2 is achieved in outer space and used as lab rating. For max efficiency I work on 600w/m2 and 16% efficiency, simply as a tolerance, as the latest NASA panels are pushing 22% but we are not able to access them, plus the panels are quickly de-rated at temps above 25 degC and the number of hours solar impact perpendicular to the panel. The MPPT controllers certainly assist with the optimisation, I just think the output is a lot less than perceived, hence why my panel area and watt output is high for the 6amp load- intermittent - from the 60L engel.
    Happy to stand corrected, but from a marketing perspective, there isn't a marketing guy out there that will sell something based on real numbers, more on the maximum possible, even if its unachievable.
  6. #573
    49 Post(s)
    Cheers guys.
    Sorry forgot to mention the battery. It's a 140ah AGM.
    I'm looking at this.
    https://www.supercheapauto.com.au/p/...=en_AU&start=2
    If needed for a longer stay I've got a 160 watt folding unit.
  7. The Following User Says Thank You to jay see For This Useful Post:
    Hodge (21st January 2022)
  8. #574
    472 Post(s)
    @jay see Mate, worth checking out what @Cremulator Legend has done/did
  9. #575
    472 Post(s)
    Usage needs: You’re not currently touring John Mate, simply running a little fridge if read correctly? For this purpose I’m not a big fan of taking up full, half or even quarter open roof rack space as guaranteed Mrs See will book you in for a 2.4x1.2m Ikea pickup oneday soon…..all of us
    Please do have a gander at @Cremulator ‘s great concept, personally ran 2 x 120W easily removable yet solid panels under my DX ute rack similar many years ago (nowhere near as refined) yet still used to make ice-cubes/blocks’ in an old Trailblazer 60L freezer for Margarita Murray River afternoons on 2 x 120ah wet batteries
  10. #576
    Jun 2018
    24 Post(s)
    I think @MB is referring to the table slide I made for my roof rack, but could certainly house a rigid solar panel.
    http://www.nissanpatrol.com.au/forum...d.php?p=828198
  11. The Following User Says Thank You to Cremulator For This Useful Post:
    MB (21st January 2022)
  12. #577
    175 Post(s)
    Cheers guys.
    That's the very panel that I've got on my roof rack.
    Sent using Pixel 6
  13. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    jay see (21st January 2022), MB (21st January 2022)
  14. #578
    49 Post(s)
    Thanks guys.
    Mb as good as the slide system is I don't think I'll go that way.
    Another question.
    I'm currently using a basic redarc sbi12 isolator, what's the go if I install the panel, will both be feeding the battery while driving?
    Fridge is connected to aux battery.
  15. The Following User Says Thank You to jay see For This Useful Post:
  16. #579
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I have a slide out 100w panel under my roof rack because it’s only a 3/4 rack. The slide is simple square ally tube on each side running in ally angle slung underneath.
    It has to be pulled out to be efficient. I’ve measured 5 amps on a good day with my clamp meter.
    I don’t use a separate controller, I have the solar input on the DC/DC charger.
    John
  17. The Following User Says Thank You to jff45 For This Useful Post:
  18. #580
    194 Post(s)
    I like both these concepts, however will need to see what I can make work. The HH antenna on the rear might limit my rear options, and the rack support legs might be just that bit close for the side - thinking .......
  19. The Following User Says Thank You to PeeBee For This Useful Post:
