Page 63 of 70 FirstFirst ... 13536162636465 ... LastLast
Results 621 to 630 of 694
Thread: Jay see 1997 GU build up
  1. #621
    49 Post(s)
    All done under the bonnet. Better than what it was, but still haven't decided on which block to use, all wires are rather under the dash or up to the roof console ready to be connected ordered a couple of things for the inside..
    Last pic was before.
  2. The Following User Says Thank You to jay see For This Useful Post:
    MB (25th September 2022)
    49 Post(s)
    This has been pushed back due to others things, but I managed to get some patrol time in today.
    I've only just discovered that my rocker switches are 4 pin and the new one that I brought for the radio is a 5 pin. I'm missing pin 6 which is lower dash light positive.
    What do I use on the 4 pin switches to power up the lower light?
    Cheers in advance..
  5. The Following User Says Thank You to jay see For This Useful Post:
    MB (23rd October 2022)
  6. #623
    49 Post(s)
    Motivation day.
    Finished off the wiring, mounted all the switches on a proper housing and the UHF in the roof console. Have the carpet in for a trial fit. Will get some foam from work to use as underlay.
    Getting close now. Next will be to replace the springs to get rid of the horrible lean it has and some heavy duty sway bars as I keep breaking the front one.
    Will need a new second hand steering wheel and a radio surround that doesn't have extra holes in it, then it's time of a Roady and club reg..
    We're getting there..
  7. The Following 3 Users Say Thank You to jay see For This Useful Post:
    Cremulator (13th November 2022), mudnut (13th November 2022), Rossco (13th November 2022)
  8. #624
    Apr 2021
    Brazil
    That carpet is looking nice.
    The only thing I would change is to move the USB charger from the overhead to the lower dash. Otherwise you will have charging cables hanging from the roof all the time.
  9. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    jay see (13th November 2022), MB TD42 (13th November 2022)
  10. #625
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    I lke the switch module...good call on the USB Brazilian.
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
  11. The Following User Says Thank You to MB TD42 For This Useful Post:
  12. #626
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    I reckon the USB is a good idea. I have a one up top close to the screen so I can have a dash-cam up behind the mirror without dangling leads.
  13. The Following 3 Users Say Thank You to Brissieboy For This Useful Post:
    BrazilianY60 (14th November 2022), jay see (13th November 2022), MB TD42 (13th November 2022)
  14. #627
    192 Post(s)
    Looking good mate. Where did you get the carpet thinking about getting some for GQ down the track has coped a fair bit of mud over the years lol. . Not sure if there is any way of getting dash lights to work if switch only has 4 pins damitt but could be wrong. .
  15. The Following User Says Thank You to Rossco For This Useful Post:
  16. #628
    49 Post(s)
    I've had a USB charger there for a while, I keep the cable plugged in but only have the end poking out from inbetween the roof lining and the console. Hasn't bothered me.
    True fit Auto they're on eBay.
    Couldn't find anything to wire up the 4 pin, so for now I've ran a positive to behind the switches till I get new 5 pin ones.
  17. The Following User Says Thank You to jay see For This Useful Post:
    Rossco (14th November 2022)
  18. #629
    Apr 2021
    Brazil
    Quote Originally Posted by Brissieboy View Post
    That never occurred to me... Interesting point.
  19. #630
    49 Post(s)
    Nearly there.
    Had my son do the windscreen last weekend and between then and today I've just about finished the inside. Need to clean some more of the plastics, reinstall the fridge and fit all the plastic covers for the seats legs.
    If anyone is going to replace their carpet I strongly recommend that you buy one with all the holes cut out, saves a lot of time and a bit of guess work.
    Still to do.
    Replace springs
    New sway bars and links (will extended links pass a rwc?)
    Steering wheel or cover.
    Is it that hard to find a radio surround that hasn't been cut up with extra holes? Yes..
    Don't think I will need anything else for a rwc, but we'll see..
  20. The Following 5 Users Say Thank You to jay see For This Useful Post:
    BrazilianY60 (27th November 2022), Cremulator (27th November 2022), MB (4th December 2022), mudnut (27th November 2022), Plasnart (27th November 2022)
