27th March 2021, 05:55 PM
#541
Patrol Guru
jay see
I want to stop the power to my antenna. Reading online fist it was the purple one with a white strip, then blue, now I've cut 3 wires behind the plug and it still works.
Does anyone know.
Do you have an antenna control switch like this?
The other place to look is on the back of the head unit there is an antenna control wire that triggers power to the antenna when the stereo is turned on.
The Following User Says Thank You to Cremulator For This Useful Post:
jay see (27th March 2021)
27th March 2021 05:55 PM
27th March 2021, 06:45 PM
#542
Cremulator
Not any more. Using a AM/FM wip. That's why I don't want the antenna to work. The head unit is wired up through a switch and to the aux battery. Unplugging from the antenna will probably be best. Will see how I go tomorrow, soccer isn't till later in the afternoon..
27th March 2021, 08:46 PM
#543
Remove the inner guard to access the antenna motor and unplug it from the motor.
8th April 2021, 06:22 PM
#544
Getting a few to things done.
Unplugged antenna, now to get the flare back on properly.
Out with the old in with the new.
and finally getting this roof console sorted. Continuing tomorrow.
The Following 4 Users Say Thank You to jay see For This Useful Post:
MB (8th April 2021), mudski (8th April 2021), Rossco (8th April 2021), rusty_nail (9th April 2021)
8th April 2021, 07:56 PM
#545
The Following 2 Users Say Thank You to mudski For This Useful Post:
jay see (8th April 2021), MB (8th April 2021)
8th April 2021, 10:21 PM
#546
mudski
Yeah maybe, there's a bit of storage space in the console itself will see have it all goes.
The Following User Says Thank You to jay see For This Useful Post:
9th April 2021, 08:14 PM
#547
It's not completely finished, but it all works. Will need to find another radio surround, bloody wreckers wanted $70 I'll find something on marketplace.
The Following 3 Users Say Thank You to jay see For This Useful Post:
MB (10th April 2021), mudski (10th April 2021), Rossco (9th April 2021)
25th June 2021, 08:15 PM
#548
The Following 5 Users Say Thank You to jay see For This Useful Post:
Cremulator (25th June 2021), MB (26th June 2021), mudnut (25th June 2021), Rossco (26th June 2021), Touses (28th June 2021)
7th August 2021, 01:48 PM
#549
Lockdown has given me some spare time, so I'm going to swap out my winch.
Now my positive and negative cables from the battery are in good condition and neatly positioned in conduit to the front. Is there any reason why I need to change them? What should I use to give the ends a good clean?
7th August 2021, 01:52 PM
#550
jay see
What size are the existing cables ? Runva 13xp comes / needs 35mm2 .
With the terminals just use something abrasive with some CRC , Lanolin etc...
