Page 41 of 70 FirstFirst ... 31394041424351 ... LastLast
Results 401 to 410 of 694
Thread: Jay see 1997 GU build up
  1. #401
    49 Post(s)
    It's in..
    Need to make up a battery bracket to stop it from sliding left and right. Then repostiton the cables and fuse to neaten it up. I've also ordered a double Anderson to run off the battery, so will need to find a place for that.
    Pretty happy with how it's come up. I always wanted to put the battery there.
  2. The Following 3 Users Say Thank You to jay see For This Useful Post:
    AB (16th February 2018), Hodge (29th June 2018), rusty_nail (24th February 2018)
    49 Post(s)
    Progress report.
    Battery is now completely secured. It sits on a 3mm plate that is screwed into the draws frame. Strapped over the center and held down it's a custom made battery clamp to stop it moving left to right.
    Draw got welded today and is back in. Double Anderson and genuine weaco plug fitted. Will have to move the fuse box to the cage as well, them will fit everything to a board and neaten it up with some conduit.
  5. The Following 2 Users Say Thank You to jay see For This Useful Post:
    mudnut (23rd February 2018), PeeBee (23rd February 2018)
  6. #403
    49 Post(s)
    Question.
    The double Anderson is for the fridge and solar. There's a 10a fuse for the fridge wired on close to the plug, but do I need a fuse for the solar, or having a regular does the same thing??
  7. #404
    49 Post(s)
    One down one to go.
    Dual oil and temp next.
  8. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (26th April 2018), mudski (24th March 2018)
  9. #405
    462 Post(s)
    Those Redarc Gauges are good hey. I have the same in mine.
    jay see (24th March 2018)
  11. #406
    49 Post(s)
    Yeah they are, but not bloody cheap that why the other is still to come.
  12. #407
    Coming along nicely there.
  13. The Following User Says Thank You to nissannewby For This Useful Post:
  14. #408
    49 Post(s)
    Cheers mate.
    Slowly but surely getting there.
  15. #409
    49 Post(s)
    Finally got around to running new wire from the rear fuse box to under the dash.
    Pulled out the seats and pulled back the carpet. After a little sponge bath to the floor I ran a 7 core trailer and new wires to behind the centre console. Now it's all one piece no more joins.
  16. The Following User Says Thank You to jay see For This Useful Post:
  17. #410
    Can see some Dyna matt coming up, like Matt said its getting there buddy well done
    big pat on your back mate, well done
