Page 33 of 71 FirstFirst ... 23313233343543 ... LastLast
Results 321 to 330 of 710
Thread: Jay see 1997 GU build up
  1. #321
    465 Post(s)
    sounds more water friendly as well, a good upgrade imo
    What brand winch do you run??
    Mines very water friendly. It never sees it. Apart from rain water. Lol.
    Mine is an old TJM Ox.
    49 Post(s)
    There's some things I can do, some things I can't and then there's the ones if I fark up it's going to cost me time and money. I know my limits.
    The light bulb came on re: the solenoid and I think the problem was, I was looking at Ben's pic wanting to wire it up to my handheld controller, not a separate switch as in that pic... I think.. Anyway sorted now.
    The patrols in getting some goodies fitted and I got them to wire it up. Saves me blowing up a perfectly good solenoid or anything else for that matter.
    Ok.
    Looks like my hand held was the problem all along.
    Now that I now that my controller is no good and don't like the chances of finding one I need to run a in cab switch. I also want to have a push button near the winch on the bullbar to spool in/out while not in the car. If i'm going to do this, it might as well be pobably. Will move the solenoid to the engine bay.
    I think I have gotten my head around Bens pic, That said I still have a few questions.
    This the switch I'm going to use inside
    http://www.ebay.com.au/itm/231996221...%3AMEBIDX%3AIT
    This one on the bar
    http://www.ebay.com.au/itm/132005868...%3AMEBIDX%3AIT
    I've done a litte drawing of how i think it all goes, just not sure on 8 & 7.
  4. #323
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    You'll get a hand controller cheap on eBay if you want
    Sent from my E6653 using Tapatalk
    Lucus30's 1999 GU ST TB45E
  5. #324
    49 Post(s)
    Dosen't it need to match the winch?
    I had a quick look the other day and didn't find one for a T max, besides the solenoid still needs to be wired up.
  6. #325
    Sep 2013
    16 Post(s)
    Your using a different solenoid so why would controller matter ?
  7. #326
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Jay see think of it this way the switch you want to put in the cab is the same switch on the controller
  8. #327
    49 Post(s)
    IDk.
    I'm ditching the whole hand held controller now.
  9. #328
    49 Post(s)
    Winch switch is worked out. Helps when you have a switch that works.
    Now for another question. I going to run an isolator switch as well do I need to run either one through a relay?
  10. #329
    Advanced Ryanbaxwar's Avatar
    Dec 2016
    Mandurah, WA
    its nice to see that color blue! if got the same but its a 98.. dont see to many of them anymore
  11. The Following User Says Thank You to Ryanbaxwar For This Useful Post:
    jay see (23rd January 2017)
  12. #330
    49 Post(s)
    Quote Originally Posted by Ryanbaxwar View Post
    Will look even better when I do the windows.
    Yeah not many around.
