Page 66 of 72 FirstFirst ... 16566465666768 ... LastLast
Results 651 to 660 of 714
Thread: Jay see 1997 GU build up
  1. #651
    49 Post(s)
    The Rose joint ends. Are not designed for this type of work and wear out fast. The link part itself is fine.
    No message from you mate...
    Check now..
    49 Post(s)
    https://patrolapart.com.au/product/h...-patrol-gu-y61
    Is this what your talking about..
  4. The Following User Says Thank You to jay see For This Useful Post:
    mudski (26th May 2023)
  5. #653
    465 Post(s)
    Yep! They have seemed to have dropped the price since I last looked.
    jay see (26th May 2023)
  7. #654
    49 Post(s)
    My control box has been sitting on a couple of dodgy brackets and some cable ties for long enough. I would like to mount it behind the bar as there's heaps of room and it will be better protected, but for now this would do..
  8. #655
    465 Post(s)
    Looks like you have plenty of room to hide it in the bar there mate.
  9. #656
    49 Post(s)
    So I decided to bite a big bullet and get a pre trip inspection done. I knew that I was going to be up for a fair bit.
    While it was there I got a full exhaust system fitted as the original was well due for a change.
    I've ordered just about all the parts and reckon I can do everything at home with no more than $2500.00.
    Some of the prices in the quote are over the top and some of the parts that I purchased were on sale at patrol a part.
    Busy weekend with a good outlook..
  10. The Following User Says Thank You to jay see For This Useful Post:
    mudski (21st February 2024)
  11. #657
    465 Post(s)
    What’s it like with the new pipe?
    jay see (22nd February 2024)
  13. #658
    49 Post(s)
    Sounds better and there's no more leaks. Haven't got it out for a decent run yet..
  14. The Following User Says Thank You to jay see For This Useful Post:
    mudski (22nd February 2024)
  15. #659
    49 Post(s)
    Got a few hours in today.
    Radius arm bushes were last changed in 2015
    Sway bar, Panhard, radius arms and steering rod all out.
    The metal bush from the radius arms fell out..
    Just for you @mudski those links.. I did buy the ones from patrol a part and will be replacing them.
    Had a look at the rear trailing arms and with the rock sliders in the way of the bolts. The sub tank needs to be removed to move the sliders out of the way. Don't know what I'll do about it..
  16. The Following 3 Users Say Thank You to jay see For This Useful Post:
    AB (23rd February 2024), MB (24th February 2024), mudski (5th March 2024)
  17. #660
    49 Post(s)
    Ok, just about got everything done in the driveway at home.
    The ac compressor has decided that it doesn't want to come out. Got the 2 bolts from underneath out and one next to the engine mount, there's one more somewhere between the tensioner and the compressor. I've taken out the only 2 that I can see and it still won't budge. It needs to pull away from the block but it won't..
    That and the trailing arms, which are going to be fun to get out. Not looking forward to tomorrow.
    A bit of battle scars.
    Took off some skin when the end of the spanner which I was using as leverage slipped and caught my skin.
  18. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (3rd March 2024), mudnut (2nd March 2024)
