Page 46 of 69 FirstFirst ... 36444546474856 ... LastLast
Results 451 to 460 of 687
Thread: Jay see 1997 GU build up
  1. #451
    461 Post(s)
    You should be able to remove the lower housing of the fridge John. I would then make up some sort of brace inside the housing so you can screw bolts into it for a better permanent mounting option. That front strap is already pulling away at the mount point and you've only just put it in. Its only going to weaken in time and make it worse.
    jay see (24th March 2020)
    49 Post(s)
    Yeah, was thinking of making up another plate this time rectangle to over the whole bottom of the fridge and a smaller one to set inside the bottom cover.
  5. #453
    May 2016
    lower west victoria
    30 Post(s)
    Hey what's the fridge like for an armrest? Is it too high, too long or perfect???
  6. #454
    49 Post(s)
    Perfect hight, but is quite long. I've pushed it forward as much as possible so I can still grab 1st (auto). That makes it just about flush with the rear of the front seats.
  7. #455
    49 Post(s)
    Took the fridge out to see how I could bolt it down. The bottom section is in two parts. One is about 1/3, the front section where the cable inputs are. The rear section is sealed to the main body along the sides and around the rear. It also has 4 screws along the red line. Taking them out doesn't do anything to the rear section.
    Another way could be with a couple of L shape brackets, one on each corner at the rear, only concern there is if I use a self tapping screw that's about 15mm long will I hit anything on the inside. I didn't think I would. There would have to be at least that much clearence around the unit.
    The front I can easily screw through the cover into the plate.
    Any other thoughts..
  8. #456
    461 Post(s)
    Whats under the rubber feet I can see to the right of the pic? I would assume there is a screw under this. If there is, maybe use this screw hole as a mounting point?
    jay see (25th March 2020)
  10. #457
    49 Post(s)
    That was the first place I looked when I took it out of the box. Nothing, peeled back the rubber and nothing.
  11. #458
    461 Post(s)
    Other option is to make a mounting plate for the outside of the case, which can be screwed into the part of the casing where you can do so and then Sikaflex the front section of the plate to the base. Or drill right through the insulated fridge section and bolt it down onto a plate. Then just silicone over the bolts on the inside. Use stainless bolts though.
  12. #459
    May 2016
    lower west victoria
    30 Post(s)
    Keen to see what this looks like when it's done. I've started looking for an arm rest for my left arm, a fridge may be the answer???????
  13. The Following User Says Thank You to 10G For This Useful Post:
    jay see (27th March 2020)
  14. #460
    49 Post(s)
    Made up some pieces at work today. Bit of a rush job, but wanna see if they work out.
    The grey plate will be bolted down like the old one, but this time the stainless sleeve will be bolted to the plate. I've got a piece of form for the fridge to sit on in the sleeve. Will see how the other pieces fit once the fridge is bolted down.
    The stainless is what they call rimex. The other parts once fitted correctly will be powercoated then painted the same colour as the interior code K I think it is.
  15. The Following 3 Users Say Thank You to jay see For This Useful Post:
    mudnut (28th March 2020), mudski (27th March 2020), rusty_nail (28th March 2020)
