Page 52 of 69 FirstFirst ... 242505152535462 ... LastLast
Results 511 to 520 of 690
Thread: Jay see 1997 GU build up
  1. #511
    That's a knot yeah?
    I was going to use hammer lock. I've got the same hook bug rated 3.2.
    Hi mate, if you are going to but that rope lock the cut that tab off and seal the end with some heat shrink so it doesn't frey. If you splice in a loop to the other end for your hook all you do is put the loop through the hook hole the the other end through the loop. Lasso. That way there is No metal thimble to wreck your washing machine either.
    Here are photos of mine. I did the splice loop ans fitted the sheath to the loop.
  4. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    jay see (10th October 2020), MB (11th October 2020)
  5. #513
    49 Post(s)
    The rope has a loop on the hook end already.
    Is will work??
  6. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (11th October 2020), MudRunnerTD (10th October 2020)
  7. #514
    192 Post(s)
    Yeah that'll work good. Best to minimize the hardware if ya don't need it. Have a hook and rope on work car and just snitched like that. .
  8. The Following User Says Thank You to Rossco For This Useful Post:
  9. #515
    Is will work??
    Yeah mate, when that is pulled tight it will be identical to my pics. Perfect.
  10. #516
    472 Post(s)
    Rocking & Rolling Now Jaysee Mate!
    You’ve got your new welder, have a crack at a four sided tacking of an 8mm x 30mm rod or a half 8mm cut chain link in the corner of your winch spool?
    Daz can guide you through a decent monkey fist type knot or double granny half arse it like me :-)
    Sometimes we desperately need those extra few rotations beyond 8 maybe to say 3 overlapping hitched after a fixed mechanical knot?
  11. #517
    49 Post(s)
    Nah, I reckon I'll go that little strap thingo, but I will have a couple flags on the rope one at 1st full wrap of the drum and another at 2nd.
  12. The Following User Says Thank You to jay see For This Useful Post:
  13. #518
    472 Post(s)
    Pinkies covered in mud, I’ve watched the 5<>10 minute strappy installation YouTubeys....Impossible :-)
    jay see (13th October 2020)
  15. #519
    49 Post(s)
    Redrill and tap might be the easiest way.
    I'll worry about it when I get to it.
  16. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (11th October 2020), PeeBee (12th October 2020)
  17. #520
    not a fan of those hooks only because that clip bends very easyly
    other than hat if its rated and does the jod alls good
  18. The Following User Says Thank You to threedogs For This Useful Post:
