10th June 2014, 08:05 PM
Luggage trim removal
Hi,
Anyone got any tips for removing the upper and lower luggage compartment trim on a GU VII wagon? I'm working on the passenger side.
I've removed the rubber door seal and can see a couple of mounting clips on the rear vertical pillar but I'm not sure if these pop off or if they slide down. It looks like you could slide the trim down off the clips, but it's hard to get a good grip and I don't wanna break anything if I'm doin it the wrong way. I've got a set of trim removal tools too but haven't gone too hard with them until I know I'm going about it the right way.
Hoping to remove the trim without breaking too many, or any, clips
Thanks,
Nick
10th June 2014 08:05 PM
10th June 2014, 08:07 PM
have you got a trim removal tool?
I used to cruise... NOW I PATROL!
10th June 2014, 08:10 PM
i picked up a plastic (better than metal) set from autobarn for 15 bucks, 5 tools in total. makes the job very easy
10th June 2014, 08:11 PM
Yeah, got a set from SCA. Don't know how well they'll work with the Patrol clips ..
10th June 2014, 08:14 PM
well yeah, locate the clip, slide your tool under it, pry it away gently. work your way around
10th June 2014, 08:19 PM
Ok, so it's just a matter of working the clip away from the metal pillar, not the trim from the clip?
Thanks!
10th June 2014, 08:21 PM
11th June 2014, 07:39 AM
how did ya go mate. my ones are currently off the vehicle, if you want me to take pics of the reverse side i can do it tonight?
11th June 2014, 07:46 PM
Yeah got the trim off thanks. Worked the first one (lowest) with the tool then just yanked the rest off.
