Results 1 to 10 of 10
Thread: lovells or not lovells
    Hi I resonantly bought a zd30 guII 2001 patrol with what looks like old 4 inch lift and 35 inch tires think the cars had a hard life, but my main question is I have had lovells in mt triton really happy with them don't know how well they will go with the GUII patrol, My brother with GUI 2.8 went with efs for not a bad price really good cross over nice extension but the ride a bit hard has anyone had lovells in the gu will they have the cross over and extension any input would be very much appreciated cheers
  2. The Following User Says Thank You to tristo89 For This Useful Post:
    PMC (6th June 2014)
    ohh yeah sorry looking to go 2inch and will the 35 go okay with 2inch
    Hardcore
    Coffs Harbour
    Quote Originally Posted by tristo89 View Post
    G'day tristo89,
    I had a Lovells set-up over ten years ago on two GQ's that I had and I did not like the way the springs performed off road. They were fine towing my 3 tonne boat on the highway unfortunately they were not that good off-road. That said, they could have improved over the last decade and have made a better spring set-up.
    As advised my Lovells were on a G/Q and not on a GU set-up. You need to ask yourself the first question, what do I want to do? ie towing or dedicated off road work or a balance of both. When you can answer that question, this will allow the various suspension mobs to advise you on which spring rate is best to suit your needs.
    Regards,
    PMC
    The halls been rented the bands been paid, time to see you dance!
    yeah mainly of road 4x4 driving bit around town but not to fussed cheers for the advice
    Hardcore
    Coffs Harbour
    G'day mate,
    Give Zordo a call in Brisbane, he is brilliant when it comes to suspension set-ups and he is reasonably priced.
    He handle's all 4wd suspension kits and also recovery equipment. I think off hand he stocks the following gear!
    EFS, LOVELLS, DOBINSONS, TOUGHDOG, RANCHO, IRONMAN, BLUE MAX, BILSTEIN, KONI and various other brands. He also sells the following;
    EXTENDED BRAKE LINES $50, EXTENED BRAIDED BRAKE LINE $80, COIL SPACERS from $46pr SUPERIOR ENGINEERING PRODUCTS also at good prices.
    PH - FAX 07 33512692 OR 0418780611
    Regards,
    Paul
    cheers for the advice guy don't know how if it will help being in nsw
  9. The Following User Says Thank You to tristo89 For This Useful Post:
    PMC (8th June 2014)
  10. #7
    Hardcore
    Coffs Harbour
    He delivers all over Australia!
    Regards,
    PMC
  11. #8
    Advanced crazyenough's Avatar
    Quakers Hill
    I contacted Zorda for a 2" with 33's , dual battery, steel bar and winch for all round driving and off roading and he advised to go the Koni's with Dobinson springs. Reading up on the Koni's they seems to have a good reputation for comfort and ability.
    There are quite a few different configuration out there it all depends on how much you want to spend and what what you want to use it for.
    2009 ST-L with a few goodies.
  12. #9
    yeah was mainly looking at the lovells or efs as they are quite cheep lovells like under 700 for the 2inch lift kit efs 1k for hit but that thanks for the advice
  13. #10
    Dec 2013
    Australind WA
    I was looking at a lovells kit for my GQ ute let me know how u get on
