12th February 2011, 09:10 PM
DIY advice
G'day guys,
I am new to diesels and just chasing some advice on some DIY mods that i can to my 08 crd that will maybe improve longevity and performance? Any help would be great
Cheers Trav
12th February 2011 09:10 PM
12th February 2011, 09:45 PM
To increase performance I would be fitting a bigger exhaust (2 3/4" or 3") and a performance engine chip.
For reliabillity you need to stay on top of routine servicing using good quality lubricants and filters. For peace of mind I recommend fitting boost and exhaust gas temperature gauges to all turbo diesels, those 2 gauges can tell you a lot about what your engine is doing.
You could also fit a crank case ventilation filter to stop oil mist going through your inlet system and fouling the mass airflow sensor.
Tony
13th February 2011, 12:15 AM
Trust Tony, have a look here he is our tech advisor, and desn't have shares in any 4wd accessory shops as far as I know. LOL
Tim
13th February 2011, 12:27 AM
I am he, fear me
Pretty much what YNOT said. Yours is still under warranty I assume so be careful with some Mods which Mr Nissan takes a dim view of...
Performance - Chip and Exhaust
Reliability/Longevity - EGT gauge, Scangauge are 'Must haves' IMHO, then a catch can or keep an eye on the MAF sensor is a good idea. Stick with genuine filters etc unless you know what you are doing and watch out for contaminated/dodgy fuel.
13th February 2011, 08:38 PM
Yeah still got about a years warranty to go so maybe i will wait until then to do a chip? probly do an exhaust and some guages. What is the scangauge by the way?
13th February 2011, 09:54 PM
Would changing the exhaust and adding gauges put warranty in jeapody? I understand that the exhaust and gauges wouldn't be covered by Nissan warranty
13th February 2011, 10:00 PM
I am he, fear me
patroltrav
The BEST $200 you'll spend on your CRD www.scangauge.com.au/
They plug straight into the OBD port under the sterring wheel and sit quite nicely on top of the column in front of the Odometer the only other gauge you have to buy is an E.G.T.
szaf (13th February 2011)
13th February 2011, 10:06 PM
I am he, fear me
szaf
The prev owner of mine had a hassle when the Turbo Flange Studs broke. Nissan blamed the aftermarket exhaust. I subsequently cracked the exhaust at the flange and the dump pipe didn't line up to my satisfaction so I got it bent slightly and a further support added at the Gearbox so Nissan were probably right I spose.
Apart from something like that you shouldn't have any hassle I'd imagine. The best way would be to ask your Nissan Dealer and then get the exhaust done and then get them to retune the VNT adjustments etc to suit. That way it's all in writing I spose.
13th February 2011, 10:42 PM
Being a CRD engine it shouldn't need any VNT adjustments with the new exhaust. (I'm not saying it won't, just that it shouldn't!)
Tony
13th February 2011, 10:55 PM
I am he, fear me
YNOT
Tony
Hiya Mr T... Hmmm Mr T, if that sticks don't blame me...
Yeah I agree, I didn't explain it well at all did I...
In another way what I meant is get Nissan to do a tune and diagnostics after the exhaust mods. That then means you have something in writing that the engine is within specs and if something goes wrong you can say "But, Hey, you did the inspection and tuning and it's within specs".
Dunno if it would be worth it but about the only idea I can think of if anyone is nervous about warranty and Nissan baling out from say an Intercooler failure by using the Exhaust mods changing boost presures as an excuse.
