14th May 2016, 05:26 PM
#31
Right so I have had the injector pump rebuilt. Put the pump back in and dialed in it in at .72 which was as close as I could get it. It still seems to wind over about 5 or 6 times before it starts when hot. I'm thinking the lift pump now. The pump was worn a little so Alberts diesel said, so it was a good move to get that fixed and it is a little better to start but still not perfect yet.
14th May 2016 05:26 PM
14th May 2016, 07:41 PM
#32
Grrr bloody annoying, good luck with it. Good to see how the lift pump goes, hopefully well.
Haven't touched mine yet, should get round to it soon, been a bit busy. . .
14th May 2016, 09:15 PM
#33
Rossco
Wow Rossco. You still having issues with your pump?
14th May 2016, 09:43 PM
#34
mudski
Yeah still temperamental to start, sometimes good but most times takes a fair bit. The running away issue is sorted but need to take it back again to hopefully get it to start nice. Might try and get into it this week maybe.
14th May 2016, 10:12 PM
#35
Rossco
I keep meaning to ask JPC about why there is a one way valve inbetween the filter and pump. I know what it does, but why....
Bugger about the starting issue.
14th May 2016, 10:49 PM
#36
Travelling Podologist
As far as I know the reasons for fitting a one way valve are either to prevent a loss of prime, usually an attempt to stop fuel draining back to the tank because of either a hard to locate air leak, or a worn pump. (It may be possible that some pumps are not designed to hold prime & thus require a one way valve to be fitted) , or just to make the process of priming easier.
15th May 2016, 01:23 AM
#37
Slight leak in on of the injector lines. Tightened it up and double checked the bolt where we put the dial gauge in which some how we didn't put the copper washer in. So I bent my arms In some funny ways yet again and got the bolt out put the dam washer on it and I think it is fixed. I will know properly in the next day or so about the starting issue as for power I intend on taking it for an outlet run which before I could get 100 in 4 th to get up the hill comfortably. It will be interesting to see if there is a slight gain with the pump rebuilt and the timing at .72
25th May 2016, 04:15 PM
#38
Little bit of power increase from advancing the pump but not much. It still had starting issues so a mate of mine which is a diesel mechanic and is also smart with power in cars put an ameter on the starter motor, he also checked a couple of other things on the starter and came to the conclusion that is might be tired so we put another one in and problem solved. Starts like a gem now
