26th May 2014, 10:16 AM
Patrol Guru
TD42t Turbo water line
Hey guys,
Doing the old conversion and chasing the long water line from the turbo that heads to the front.
I know pertek/enzed could do one but looking for the stock setup at this stage to keep it nice and neat. I have EVERYTHING else except this line.
Hoping someone has done a upgrade on turbo and has the line laying around somewhere.
Matt
26th May 2014 10:16 AM
26th May 2014, 10:39 AM
Legendary
Hey Matt what are the fitting that it needs?? If you cant find one i can get the stuff you need to make it out of Braid. I made my own water and oil lines on the rx not long ago and i used these fitting that lock and seal themselves so you can cut them to the right length to suit.
From memory in the rx the banjo fitting was M14 and i used -6 braided line
26th May 2014, 01:20 PM
Patrol Guru
its just the banjo bolt on turbo and will be going to a fitting i will make up on other end. I was just hoping someone would have stock one around to look a bit more factory. I've got some stuff here to make temporary one as I know where one is complete but its in echuca at a mates place.
Those bits you post look interesting though george. thanks for that will look at them now.
26th May 2014, 01:36 PM
I might have one but I'm all the way up here.
26th May 2014, 03:02 PM
Legendary
matfew
its just the banjo bolt on turbo and will be going to a fitting i will make up on other end. I was just hoping someone would have stock one around to look a bit more factory. I've got some stuff here to make temporary one as I know where one is complete but its in echuca at a mates place. Those bits you post look interesting though george. thanks for that will look at them now.
They're pretty good the ones i used were 3 pieces with an olive thats crushes the nylon tubing to stop it leaking and lock it i to place, then the banjo fittings had a an base with tapered seat to seat inside to fitting on the braid. I made oil feed, water in and out and the turbo drain, but the turbo drain hose was braid over oil resistant hose.
Heres the banjo fittings
And this is how it works
