21st May 2014, 07:14 PM
You have gas fitted then... the big one is your ecu and has a 10mm bolt that holds the plug in. . Once undone you can disconnect the plug and tip upside down to see if water has got to it.
The other unit is for your gas system.
21st May 2014 07:14 PM
21st May 2014, 07:28 PM
I bought it for the body mainly but it has that much wiring shit under the bonnet it scares me ,im in the middle of fixing 3 electric doors 2 low beams 2 spot lights maybe fuelpump power mirrors .ive been on the computer for days.i didn't realise how different it is to my good old diesel model .I cant even find if a fuel pump runs a fuse . it couldn't even handle a little squirt under the bonnet .
21st May 2014, 07:38 PM
the big ones got 4 bolts thathold abig gold plate, the little ones just sitting there
21st May 2014, 07:39 PM
td42shayne
Mate mine just got a wash today with no issues... water on the ecu is a real problem but cant say this is your problem.
All you can do is go through process of illumination. ..
21st May 2014, 07:55 PM
so should I undo the 4 bolt big one, it looks so dry under there.i thought I could see a bit of smoke and smell it under the bonnet be fore it stopped.
21st May 2014, 08:01 PM
Takes 5min.... and that is one thing you can cross off your list.
21st May 2014, 08:21 PM
#17
aussie I took it off undid the bolt unplugged turned upside and its not wet .where do you reckon next
21st May 2014, 08:37 PM
#18
The 747
There is only 4 or 6 screws holding the casing on the ECU, it's worth taking them off to have a look for any corrosion in the ECU. It will be very obvious and only another 5 mins.
21st May 2014, 08:51 PM
#19
bugger I just put it back. the one I just done had a row of green plugs and one bolt that holds them all in,i got the right one I hope.thanks fellas
22nd May 2014, 09:20 AM
#20
all fixed cant b elieve it.on the drivers side next to battery theres a plate with 2 screws bolt head,inside theres a little black box thing looks like relay sorta,took little cover off two fuses in there .changed fuse and wella shes going.theres a sticker that says something like ign ac ,im a happy chapy thanks fellas
