25th October 2019, 02:50 PM
No ac and no air through vents
Hey all,
Just picked up a gu patrol ti model tb45 with auto climate control, im finding small little things to fix but this ones the annoying one.
Basically i have no cold air at all which i probably have no ac gas but i alsp have no air coming through the vents they only come through the window vents and as well as the rear vents when i turn them on
Anywhere where i should look first?
Cheers fellas
25th October 2019 02:50 PM
25th October 2019, 03:18 PM
Make sure that the cables from the control to the heater box are connected and working properly.
25th October 2019, 04:06 PM
If the fan is working, try checking that the filter isn't blocked. https://www.youtube.com/watch?v=Fh7bbjuzXmo It will be reverse for right hand drive.
26th October 2019, 03:30 AM
Thanks for the replies solved the no ac problem there's no belt attached for some reason easy fix hopefully.
As for the vents i suspect its either the control unit faulty or wiring because i cycled through all the modes all the air is coming from the window vents regardless i select the normal vents and foot vents. There's no cabin filter and i unplugged and reconnected the control box
