14th February 2014, 08:16 PM
2" or 3" what's better to fit if running 33's
Hey all just trying to decide what lift I want I can get a 3" king spring with amada shocks for $895 that includes brake lines and castor correction bushes
Just don't know what to get
14th February 2014 08:16 PM
14th February 2014, 08:26 PM
14th February 2014, 08:45 PM
2inch with 33's no problem at all... once you go to 3 inch then you need to start looking at spending more on lots of other crap!!!!
14th February 2014, 08:54 PM
2 inch is a far simpler lift as you only need springs and shocks.
3 inch gets you into caster correction, sway bar extention links, possibly panhard bars, longer diff breathers, possible extended brake lines
Mic
The Following User Says Thank You to happygu For This Useful Post:
Bloodyaussie (14th February 2014)
15th February 2014, 11:16 AM
I ordered 3" with everything
15th February 2014, 11:19 AM
As it was cheaper and in the long run I want to run 35s just want the clearance
15th February 2014, 11:28 AM
Moderator
Reconsider the caster correction bushes as they are junk and your way better leaving the Nissan rubber bushes in place. Buy bolt in 3" drop boxes for the win mate.
Check out my Toy -->
Rogue Dung Beetle
15th February 2014, 11:44 AM
#8
Is it worth getting this order cancelled as it doesn't come with much looking over the fine print and getting a 2" kit from suspension stuff
15th February 2014, 11:53 AM
#9
Moderator
I assume the Amadas in the kit are Not the remote res units?
The 3" kit will need
Shocks
Springs
Brake lines
Sway bar extensions
Some kind of caster correction.
Diff breather extensions.
Rogue Dung Beetle
15th February 2014, 12:01 PM
#10
Okay so I can send a message to them and say don't cancel it can you supply sway bar extensions
