21st September 2014, 10:45 AM
Hardcore
Nice for $450 you've got great draws. Probably the fridge slide cost you more
Lucus30's 1999 GU ST TB45E
21st September 2014 10:45 AM
21st September 2014, 11:00 AM
Yeah mate, They don't come cheap. I struck a bit of luck there because a local 4WD shop needed some IT work done and I came to a bartering deal with them where I helped them out and they gave me the slide and the barrier.
The best part about these drawers (for my use) is they have dimensions for my gear. For example, my ARB air compressor case fits snug into one and the height was set accordingly. I pondered having "two levels" or a deep and a shallow drawer to get the fridge lower but then couldn't be bothered with the extra work. The drop slide also makes it a lot easier to get into the fridge.
2009 ZD30-CRD Patrol ST Wagon. Bullbar, IPF Spotties, Snorkel, BFG285/70R70, 2" OME Lift, Rear Drawers, UHF, Scangauge, VDO Boost and EGT Gauges in an A-Pillar Pod, More bits
28th October 2014, 02:40 PM
that's awesome. they looks great. I am hoping to make a set of my own very soon. what did you line it with? I have been advised to line it with marine carpet to avoid any moisture being absorbed and warping the wood.
