Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: What causes gears to bite??
    Legendary snicko's Avatar
    Apr 2011
    Eyre Peninsula SA
    Hi Guys
    My daily drive is a 2006 GU 3L TD (manual) which we bought new. After the 80,000km service (which changed all the oils) I started missing gears.
    ie Changing up from second and finding fifth and or changing down from fourth and finding fifth etc (other combinations as well)
    Also when I change gears they seam to really bite to go in and you can really feel it through the gear stick.
    I took it back and they checked to see that the right oil and quantity was used.
    Not sure what GL4 or GL5 is but my mechanic said they put Castrol T...something!! in it.
    or is Castrol T.....something the wrong stuff??
    I'm not very tech savy but could I have a problem with the gear box and the changing of the oil is just a coincidence?
    (All the towing it has done is with a camper trailer and we only tow in 4th.)
    GU Patrol: 3LTD :- The cheapest option is to buy the right thing the first time! - YEP WORKS FOR ME!!
    Front and Rear "LOCKED" WOO HOO !! squeal, scream, squeal toot toot !! hahahaha
    NISSAN PATROL.com.au .......stickers........done by Snicko.......I know you want one....
    http://www.nissanpatrol.com.au/forum...screen-Sticker
    The master farter
    mudski's Avatar
    462 Post(s)
    Take the side filler plug off and stick your finger in there. See what colour it is. If its red then they have put in auto trans fluid.
    Castrol VMX-M is what is supposed to be used in the manual trannies...Which aint red. Castrol T...something sound like they put in Transmax which is for auto's...
    Welcome back too bud...
    Remember the plug on the rear is for the transfer case, there should be red oil in that. As per the book auto trans fluid is supposed to be in that. But I just used 80/90...The plugs for the gearbox itself are on the right side of the box.
  4. The Following User Says Thank You to mudski For This Useful Post:
    snicko (14th May 2014)
  5. #3
    Apr 2011
    Eyre Peninsula SA
    Thanks for the reply mudski
    I rang the garage where I had the service done and on their system Castrol VMX-M 75/85 was put in.
    When I spoke to the service manager the first time he told me that Castrol T something was put in it so not sure whats going on.
    Like you suggest I will go and give it the finger test!!!! hahahahaha
  6. The Following User Says Thank You to snicko For This Useful Post:
    Stropp (21st May 2014)
  7. #4
    Feb 2011
    Shed
    45 Post(s)
    Howd ya go Snicko?
  8. #5
    Apr 2011
    Eyre Peninsula SA
    I ended up ringing a Nissan Dealer and he said Castrol VMX80 is the oil needed.
    Went back to the garage who did the service and they were very good. Changed the oil to VMX80 and I only had to pay for the new oil.
    Much better.
  9. #6
    The master farter
    mudski's Avatar
    462 Post(s)
    That's odd as I'm running vmx-m in my troll and it's fine. How old was the oil that was originally in there?
  10. #7
    Jan 2013
    Castrol books normally has multiple oils that are suitable for use.
    Ive run multitrax, vmx and a mates running tfc450. None with shift problems.
  11. #8
    The master farter
    mudski's Avatar
    462 Post(s)
    I wouldn't be using tfc450 in a Patrol box. That's an equivalent to straight 90. Would make things hard to shift I would think.
  12. #9
    Apr 2011
    Eyre Peninsula SA
    80,000km first change
  13. #10
    The master farter
    mudski's Avatar
    462 Post(s)
    Quote Originally Posted by snicko View Post
    Thats a while in the gearbox... Wonder if you had dropped the vmx-m and replaced it again with vmx-m if it would have been better or stayed like it was. Sometimes a diff need a few oil changes before it comes good... Don't matter now though....
  14. The Following User Says Thank You to mudski For This Useful Post:
    snicko (21st May 2014)
