1st May 2014, 05:48 PM
1st May 2014 05:48 PM
1st May 2014, 05:55 PM
The rear part of the lining then drops down easily and can be removed from the vehicle. The interior light feeds back up through the hole in the panel and I then simply screwed it back up to stop it flapping around.
I then used a bit of acetone to give the ceiling a good clean up. The old felt padding doesn't cover the whole ceiling and if it isn't falling down, it comes off very easily as it is only held on by a bit of double sided tape.
Of note, there were no steel rods to be found anywhere in my vehicle.
1st May 2014, 06:02 PM
Forward ceiling panel
The forward ceiling is a little more time consuming, but not much.
The pillar covers and grab handles all need to come off, along with the sun visors and any over head lighting or consoles.
I didn't remove the B-pillar covers, as they held the lining in place nicely until I was ready to lower it down.
I also took the opportunity to tidy up the wiring to my UHF coming up the front passengers side A-Pillar.
All the felt came off easily and I will replace it all with a few sheets of dynamat or butyl sound deadener, and then some foam overlay to help with the heat coming through the roof.
6th May 2014, 06:48 AM
Yeah, good idea. Hopefully the sound deadener and replacement foam lining arrive today. I did just put a bit of expandable foam into the structural cavities at the front and rear to firm things up and insulate them somewhat. Will trim it up today once it is all set hard. Wicked stuff!
6th May 2014, 10:41 AM
Being cleaned up and ready for the sound deadener and new foam insulation.
8th May 2014, 12:19 AM
8th May 2014, 12:23 AM
Rotaredom
These posts have been copied from BenK's original thread asking on how to remove the lining located here: http://www.nissanpatrol.com.au/forum...d=1#post503896
I have closed this thread down and will copy across the info from the above thread when it gets posted up.
Toddie
