14th March 2015, 08:25 AM
#61
Enjoying the trips
Macca
14th March 2015 08:25 AM
16th April 2015, 05:45 PM
#62
A bit more progress this week with rear torsion system being installed.
Front steering damper has also been fitted.
Not much more for the next couple of weeks again though.
The Following 8 Users Say Thank You to Figjam For This Useful Post:
93patrol (16th April 2015), Avo (16th April 2015), BigRAWesty (16th April 2015), Clunk (16th April 2015), krbrooking (16th April 2015), MB (11th February 2016), rusty_nail (16th April 2015), Stropp (16th April 2015)
16th April 2015, 06:21 PM
#63
Figjam
A bit more progress this week with rear torsion system being installed. Front steering damper has also been fitted. Not much more for the next couple of weeks again though. <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=57275"/> <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=57276"/>
That's an awesome torsion setup
16th April 2015, 07:17 PM
#64
Figjam
come on Ewan, its got dust on it, you may have to give it to me to look after if its getting dusty
16th April 2015, 08:11 PM
#65
Apprentices Rule!!!
Stropp
I live closer mate, and am happy to pay transport costs......
16th April 2015, 10:31 PM
#66
Punderhead
Not quite, I'm about 10 Kim's from this weapon 😄
The Following User Says Thank You to Stropp For This Useful Post:
stevemc181 (15th January 2017)
16th April 2015, 11:00 PM
#67
Apprentices Rule!!!
Stropp
And I'm on the other side of the country, but I could move.
16th April 2015, 11:03 PM
#68
Apprentices Rule!!!
Legit question time though. Your suspension, while making me drool, looks like it is set up as race truck/ trophy truck type setup. Are your setting it up for super high speed stuff (we all know you have the power to do that) or will it still perform with decent flex when rockhopping?
Cheers!
17th April 2015, 11:25 AM
#69
It is a slightly detuned race suspension from Climax industries. Which basically means that I am running lower springs to keep the overall height down, slightly shorter shocks to suit and custom valving of the shocks when complete to compromise on and off road.
The torsion bar system on the rear is designed to try and keep the left front wheel on the ground under power and reduce torque steer.
The Durmamax sump fouled on the upper front diff bracing of the portal axle. Because I can't run tall springs and an increased bump stop, we lifted the engine another 20mm and fitted hydraulic bumps which become solid when fully compressed. This has allowed us to reduce sump clearance and maintain maximum up travel in the front end.
The radius arms are being replaced as apparantly the factory ones have potential to fail when pushed hard. These will be Superior 3" laser cut arms and not the Superflex version. Overall front end flex will be somewhat limited, but it is likely that I will pass lane change test without front sway bar so will run without if I can. The shocks all have enough stroke to allow for fairly good flex. The rear diff has a shimmed up LSD with a TJM Pro-locker in the front so will be OK for what I am prepared to climb with it as it will be carrying a touring package around as well.
The Following 2 Users Say Thank You to Figjam For This Useful Post:
Punderhead (17th April 2015), Winnie (17th April 2015)
17th April 2015, 12:03 PM
#70
The 747
Figjam
try and keep the left front wheel on the ground under power.
Yeah, I hate when that happens!!
