Results 11 to 20 of 23
Thread: 2011 st wont start
    Advanced Dougy's Avatar
    Jan 2013
    Right so I soldered it back together, end up having two breaks in it, bit fidly to do and had to scrape the insulation off wire first. Put it back on and still wouldn't start. The wires weren't quite in the plastic ring properly so I tucked them back in a bit better and it started! I unplugged the IMMU while the car was running to make sure I can drive it to Nissan without the car stopping if my soldering falls apart. Nothing happened when I unplugged it so I guess it wont hurt for the wife to drive it to the dealer as long as she doesn't turn it off! Thanks TPC, im hoping it wont cost me that much but I guess i'll prepare myself now for the bill.
    2011 ST, Steel bulbar, warn winch, snorkel, arb rear bar, uhf, dual batteries, on board compressor, 2" OME suspension
  2. The Following 2 Users Say Thank You to Dougy For This Useful Post:
    TPC (4th May 2014), Yendor (4th May 2014)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Thanks for the update Dougy,
    Once the ECU have received the signal from the IMMU that's is ok to start and the engine has started the NATS has no affect on the engine running. The worst that might happen is the security light comes on or starts flashing.
    Can you let us know when you hear back from Gary regarding the programming of the IMMU.
    Cheers Rodney
  5. #13
    Jan 2013
    Yeah Gary thinks it doesn't need programming, but hes gonna check it out for me
  6. #14
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    That would be great if it doesn't, you could easily replace it yourself.
  7. #15
    Jan 2013
    Nizzbits says the new unit shouldn't need programing, so hopefully 10 min after I get the part I will be back on the road!!
  8. #16
    Jan 2013
    Back on the road!! Got the new IMU, bolted it on and plugged it in and it started straight away. Thanks everyone for all the help!
  9. The Following 2 Users Say Thank You to Dougy For This Useful Post:
    MudRunnerTD (9th May 2014), TPC (9th May 2014)
  10. #17
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Goos stuff mate, glad you got it sorted.
    If you don't mind me asking, how much was the new IMMU?
    That's real handy knowing it doesn't need to be programmed.
  11. #18
    330 Post(s)
    X2 ^^^^^^^^^^
  12. #19
    X 3 good result.
  13. #20
    .......... TPC's Avatar
    63 Post(s)
    Not sure if I want to know how much it was after how much Nissans charged me to fix it.
    I suppose I should always check if I can do something myself cheaper.
