Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Oil for CRD
    Expert Dave_H's Avatar
    Nov 2013
    Whyalla S.A
    Yeah i agree with Mic, i'll be doing mine every 10k as 5k seems very excessive to me for what i generally use it for (wifes shopping trolley
    2008 GU6 ST 3.0 CRD Auto, 2" Lift, ARB Bullbar, IPF Spotties, Side Steps, Maxxis 980 A/T, Roof Rack.....................
    175 Post(s)
    Hodge,
    I have never done 5K oil changes ever .... in Europe they do 15K on the same oil / same motor, so I figure 10K is just fine
    Mic
    Yeh, definitely agree these can go a while between changes. Even though my oil is fairly clean, especially after the EGR got blocked. But I got into a habit of doing it as I don't do many Ks, so it's a long time between the 10k marks for me. That's why I just change engine oil and filter at around 5k, just to freshen it up a bit.
  4. #13
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    Ok so thought it about time I done an oil change myself. Done it many years ago but that was petrol vehicle.
    I bought the oil and filter today. The filter has me a tad baffled as its only a filter, not the actual metal container with the thread on it. So I'm guessing the case is part of the vehicle and you just unscrew that, pull out the old filter and replace then re screw the casing to the engine. Any care to confirm?
  5. #14
    Nov 2013
    Whyalla S.A
    Yes that's correct. Unscrew the casing and replace filter cartridge then screw back on.
  6. The Following User Says Thank You to Dave_H For This Useful Post:
    Patrol-Guy (22nd November 2014)
  7. #15
    sunshinecoast
    3 Post(s)
    when you remove the old oil filter be aware that there is a black plastic fitting in one end of the filter , you need to fit this into the new filter . if you loose it you will be up for over 200 bucks as nissan only sells it with the metal housing and you can't get it any where else .
  8. The Following User Says Thank You to nipagu7 For This Useful Post:
    Dave_H (22nd November 2014)
  9. #16
    Nov 2013
    Whyalla S.A
    I've never priced the housing/cannister until now that you have mentioned it. That is quite expensive but then again nothing is cheap these days.
  10. The Following User Says Thank You to Dave_H For This Useful Post:
    growler2058 (22nd November 2014)
