Results 1 to 5 of 5
Thread: Diesel chip
    Jul 2013
    Diesel chip
    Looking for info for Diesel chip for my GU 2003
    What would be the cost . is it something I can DIY
    Couldn't tell you the cost but I know they're not cheap. Pretty sure you'd need to get on a dyno after fitting a chip to get the best of it.
    most are around $1000-$1500, done in conjunction
    with a bigger exhaust will see you benefit most
    Beginner Onrei's Avatar
    Apr 2014
    Sydney
    I'm looking at installing a chip too. Everywhere I seem to read that the ZD30 should be done in conjunction with an exhaust.
    What can you recommend in regards to a good chip/exhaust combination? I see Roo Systems seem to have there name out there a bit.
    Also, is a 3 inch exhaust the right size for the ZD30?
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    You can get a chip from "no limits" for $150 plus delivery from their ebay store, they are a german maker and many owners of rangers, bt50's, hiluxes etc are using them with little or no problems.
    Adjustable range fro 1-10 depending on needs of power v economy wtc
    www.swat4x4.com
