Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Interesting SOLAR meter
    http://www.ebay.com.au/itm/281259576...84.m1423.l2649
    Looks like an interesting gadget to have to monitor whats going on with your panels,
    I'm going to get one
    W.A. (wandering aust)
    I run that exact meter on all my Solar installations.
    I'v used them now for over 2 years and yet to have one fail. Extremely handy little meter and I wouldn't be without them.
    My only criticisms are that they have no mounting provision (velcro on the back works a treat) and the fly leads are a tad short.
    I hard wire mine but they will adapt to Anderson or any other plug application equally well.
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    threedogs (23rd April 2014)
  5. #3
    @ Bob this might suit your needs ,
  6. #4
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    My Redarc Solar Regulator has one like that attached.
    Solar_Regulator_Remote_Monitor_Instruction_Manual.pdf
  7. The Following User Says Thank You to Bob For This Useful Post:
  8. #5
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Interesting... Beats using a multimeter ever time
    Lucus30's 1999 GU ST TB45E
  9. #6
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    What a top bit of kit, just bought 1 myself
    www.swat4x4.com
  10. #7
    I have a 50amp Anderson on the bull bar to my AUX battery.
    Now I can plug this unit in line with my Panel and see whats happening ,
    don't you love gauges.
  11. #8
    this looks the same but with out the end plugs
    http://www.ebay.com.au/itm/LCD-Volta...item3f2a266fef
  12. #9
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    We use an exact same unit called a watts up meter for the rc..
    150A rated for low to high (50v) usage..
    Most common brand is turnigy, and more than half that price.. Just need plugs
    Ballarat, Vic
    174 Post(s)
    They are good little meters provided those buying them recognise the meters’ limitations & have the understanding of how best to use them. They will tell you, depending upon where they are connected how many amps are coming in or going out .... in real time, as well as solar voltage &/or battery voltage in real time. This is useful info, but for those who want a meter to give a relatively accurate reading of a battery’s State of Charge an ammeter with a shunt is needed. The difference is that this will record amps in & amps out & with the capacity of the battery dialled in by the owner will calculate the battery’s SoC. There is no 100% accurate means of monitoring a battery because chemical reactions are affected by a number of variables, but such a monitor is the best anyone can do. However as I said, & for a lot less money, those little meters can be quite helpful once the user knows how & when to interpret the readouts with familiarity. They can also be bought far cheaper without the Anderson plugs attached. .... (Ah, I see TD has found those).
    The cheapest battery monitor with a shunt that I am aware of is the one I have in my Patrol. They are available in Oz, but can be bought from the UK for less, including postage. I bought half a dozen as a group buy on another forum & got them for $140 each delivered about 18 months ago. (saved on postage & paid no VAT/GST) http://www.foxsonline.com/cgi-bin/sh...R#aNNBM1C_2dGR Not suggesting that everyone should have one, but I do think it worthwhile to counter some of the advertising I have seen, particularly aimed at unwary 4wd’ers, selling volt meters as battery monitors. (Advertisers who have no connection to any posters here I hasten to add.)
    Cuppa
    Ps. By coincidence I have written about the exact same thing to a forum member here via PM in the last day or two).
    A Nomadic Life (Blog)
  14. The Following User Says Thank You to Cuppa For This Useful Post:
    BigRAWesty (23rd April 2014)
