Results 1 to 4 of 4
Thread: UFO led light bracket
    I brought this UFO light from Aldi's a month or so back, and very surprised how bright it is.
    We take a huge tarp when we go away with all poles 20mm powder coated steel.
    with the centre pole being 20 the UFO wont stay by itself unless you wire or tape it in position.
    I've made a simple adaptor that will suit. It's about 3" on 25x25x2 rhs drilled with a nut welded on to except a 1/4" thumb screw.
    The light itself has a few modes, which will help. Might give you ideas on how to mount other gear you have. This will keep it up high for max affect
  2. The Following User Says Thank You to threedogs For This Useful Post:
    Stropp (15th April 2014)
    Apr 2013
    looks pretty good...do you think they could be hard wired to 12V ?...I dare say they are battery ....by that I mean put a plug on them and the wiring just rolls up with the annex into the annex bag /....do they disco ? lololololol
    the one thing wrong with middle age ...is knowing you will grow out of it !
  5. #3
    Patrol God Stropp's Avatar
    31 Post(s)
    i have one and yes it does disco , looks good 3d.
  6. #4
    batteries are cheap enough, I would guess you'd get two weekends away out of a set of batteries
    Edit:: mine does not "disco" lol its either, inside led, outside led or both
