Page 10 of 15 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 150
Thread: mudnut's 'Old Trol' build thread.
  1. #91
    I have fitted the snorkel and am waiting for the paint to dry before fitting the inner plastic and flare. I can't wait to do a long trip to see if I get better mileage.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    Woof (6th October 2016)
    After a bit of drama, I have a new snorkel. I have explained what happened here: http://www.nissanpatrol.com.au/forum...k-Your-Snorkel
    I now have to make a plug of some sort for the pre-heat inlet of the filter housing. I sprayed a bit of Start Ya Bastard around any possible places that could let in water.
    The engine revs increased a when I sprayed bit near the filter to dust collector pipe and also the pre-heat inlet and pre-heat diaphragm.
    A bit of silicon around the bottom of the diaphragm housing has fixed that bit, but I will need to make the plug removeable as the carby struggles a bit in the colder months.
  5. #93
    To further enhance water proofing the engine intake, I have bought a brass reducer that uses a brass 1" plug.
    Using the copper-based silicon, I have glued the reducer into the Pre-heat elbow on the filter housing.
    This allows me to seal off the pre-heat flap instead of having to engineer some sort of seal on the flap itself.
    I have also put a ball bearing inside the diaphragm vacuum hose so it doesn't lift the flap and cause a constriction of the air flow.
    Now I can still run the pre-heat in winter, and seal it up for off road trips and it looks stock and road worthy.
    The first picture is of the driving lights I was given.
    In the engine bay, the water proof box next to the battery is for the headlight relays. There is a small black box behind the battery for the driving light relays and fuses.
  6. #94
    Only a small job but it has made life that little bit easier in the cabin. I have built a larger storage box under the radio. I used an old stereo's housing in which I glue a piece of wood to act as a lip at the front, then glued carpet inside. It is around 3-4 cm deeper, 1 1/2 cm higher and around 3-4 cm wider than the pissy little plastic original.The bottom of the box is also at a deeper angle than it used to be. Combined with the lip, it will take a lot more for the contents to slip out.
    It looks a little bit crappy as there is only some black tape on the front. I will paint it black, one day.
  7. The Following User Says Thank You to mudnut For This Useful Post:
    mudski (1st February 2017)
  8. #95
    465 Post(s)
    Your an ideas man Craig.
    mudnut (1st February 2017)
  10. #96
    Did you get around to fitting an air horn pump up to the dizzy, you'll need
    a needle valve or similar to adjust the flow.
    Pretty sure I have one here I can post to you, basically brand new.
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #97
    No, John, have had other stuff that needed attending to. I have found an old air regulator in my shed , so it mght be able to be fitted. But thanks anyway, mate.
  13. #98
    Patrol Guru
    Jul 2014
    6 Post(s)
    Wow, your engine bay is so clean!
  14. #99
    Quote Originally Posted by Throbbinhood View Post
    I don't know why. The bay has only been washed once in the 3-4 years I've had the Old Trol, and that was when I had to take it through the Surrey River. One thing about having a clean engine, is that fluid leaks are easily diagnosed.
  15. #100
    I have been checking and studying the fuel breather system, with the ultimate goal of fitting an auxilary fuel tank. I have found that the breather filter attached to the tank is connected directly to the canister in the engine bay.
    Does anyone know if this is standard for a '94 model or has it been modified?
