14th April 2014, 08:29 PM
#11
just a more recent pic of the setup, showing it will even fit with a turbo system on a tb42e
14th April 2014 08:29 PM
14th April 2014, 09:08 PM
#12
Drewboyaus
What size cable should I use between the cranking battery and the Ctek charger in the car?
I'm assuming it will also need to be protected by a (50A?) circuit breaker or fuse......
Do I also need to fuse the short link between charger and battery box?
Sent from my iPhone using Forum Runner
I'd just keep the short end to the battery box short and well insulated (if attaching the ctek to the box) and fuse the one going between the ctek and cranker at both ends and fuse to suit the wire. If the arc pack is in the boot I'd prob use 8mm twin core.
The Following User Says Thank You to megatexture For This Useful Post:
Drewboyaus (14th April 2014)
15th April 2014, 09:56 PM
#13
Travelling Podologist
You’ve got it nailed.
As well as MT’s mates idea of having the Ctek removable how about adding the the extra flexibility of being able to solar charge the aux as well. It’s only one more cable & a switch?
Triple battery setup-2.pdf
The Following User Says Thank You to Cuppa For This Useful Post:
Drewboyaus (15th April 2014)
16th April 2014, 06:49 PM
#14
CERTIFIABLY INSANE
Cuppa
Thanks Cuppa........I might not put the switch in just yet but will be in the planning......I assume would need to ensure it is switched off when the battery is charging via the alternator?
When Mega is talking about 8mm cable is that like 6B&S size (or is that too big)? Bloody cable sizing is harder to pick than a broken nose with some B&S, some sqmm, some AWG.......confusing as fark!
Cheers,
Drew
16th April 2014, 06:54 PM
#15
8mm core not including insulation but i agree its a pain when ordering/ comparing wiring, you will prob need at least 4-5 mtrs to get it in the back so you don’t want anything to small.
Drewboyaus (16th April 2014)
16th April 2014, 07:19 PM
#16
CERTIFIABLY INSANE
Is that 8mm diameter or area?
16th April 2014, 07:44 PM
#17
i was refering to diameter, have you seen the link cuppa has posted previously regarding wire calculations http://hobohome.com/news/?p=581
18th April 2014, 12:32 PM
#18
I would change the switch setup by cuppa-
Use a switch (or relay) to charge the crank battery & the AUX via the sb12. eg the relaye does a chnage over of the dcinput to output.
I use this type of setup with my work trucks as they are pacrked for long periods. The charge from the ctek should be high enough to activete the sb 12 and trickle charge both batterys.
